#101 | |
Re: Project...praise the lowered
I dig it man! A very unique build. I'm as excited as everyone else to see what you do next!
-- 1969 Chevy Build: http://67-72chevytrucks.com/vboard/s...d.php?t=461209 Quote:
The front: 17x7 245/45/17 Kumho Ecsta XS The Rear: 17x11 315/35/17 Kumho Ecsta XS |
#102 |
well next will hopefully be finish stripping,priming,painting the rear half of the frame then install front suspension.i say hopefully because im doing the frame in my drive way and we are on day number 22 of rain so its a major holdup on the build.i got my rear end ready to come home tomorrow and ordered a 444c compressor/pressure switch/4 cross drilled rotors and ceramic brake pads last night.also have my new control arms and brackets almost complete so the rear suspension should be mocked up in place real soon.i will keep you guys updated
check out my build (the start of a shaved,channeled,bagged 67 gmc with a 01 gmc frame and drivetrain) http://67-72chevytrucks.com/vboard/s...d.php?t=434253 |
#103 |
mmmmmm primer.managed to get some highbuild primer on the beast today.its so nice to see it one color again.one step closer
#104 |
67cheby
![]() Join Date: Sep 2008
Looking great ...
#105 |
VA72C10
![]() Join Date: Mar 2008
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#106 |
![]() Join Date: Aug 2010
Raymond 1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper. My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594 The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939 Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402 |
#107 |
Smooooove!
#108 |
![]() Join Date: Mar 2011
Super niiiice.
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#109 |
love the comments.good to see the fan following.my views are getting up there.so im now back at the interior.yesterday i welded in some tabs to mount the console,some studs for wire mounts,hammered out some warping on the dash,and spread/blocked some fill.back at it for an hour today i did some more blocking and shaping,and laid some fiberglass where the new cluster is mounting to the old dash.so far so good.i should have some pics tomorrow.
#110 |
Grandpa in the rustmobile...
Wow, you've got skill dude! I wish you were my neighbor or something Id love checking that truck out!!! Cab looks super clean and the hood is sweet too! I thought my truck was rusty, yours was alot worse!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#111 |
low n' slo
![]() Join Date: Mar 2009
lookin clean!!
what brand is that black primer you are using? looks like the eastwood epoxy im using on my truck.
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
#112 |
thanks buddy.actually i wish i was your neighbor.after reading your thread looks like you live in a great area.and you know how to turn a wrench.i would put you to work asap haha.keep up the good work on your build.im going to watch for updates
check out my build (the start of a shaved,channeled,bagged 67 gmc with a 01 gmc frame and drivetrain) http://67-72chevytrucks.com/vboard/s...d.php?t=434253 Last edited by (joey); 05-16-2011 at 07:26 PM. |
#113 |
its something new i bought.i laid down a coat of epoxy then hammered 2 heavy heavy coats of the black highbuild.i have used a lot of highbuilds in the past but this is by far the thickest.like glaze putty in a spray gun.i will find out the brand tomorrow.
#114 |
low n' slo
so the black highbuild is a different primer than the epoxy you used?
#115 |
yup.the epoxy was white and the highbuild black.its called Bernardo Ecenarro 2k acrylic high build filler.i had to go with this instead of the usual stuff because the shop i buy from was switching everything to water bourne .
#116 |
update on progress....heres the pics of the dash work.shows the fiberglass method i used to bond the new cluster to the old dash,then the fill and the start of shaping.just ran out of time tonight.i came home to some goodies waiting at my door.my rotors and pads.i mocked the rear ones up to the fresh blasted/painted/shaved rear end.looks great.im also going to include the mounts i fabbed for the rear trailing arms.they are going to mount in the location where the front leaf spring mounts were.just bolt in place.i also spaced them perfectly from the frame to end up mounting to the rear end where the leaf springs and u bolts mount.need some nice weather to set my wheel base/pinion angle and where the bags will mount.
#117 |
All those horrid brake components seem like theyre in your way. Send em here and I'll make good use of em ; )
Great work and awesome skills!! |
#118 |
67cheby
WOW...looking great , keep it up
#119 | |
67cheby, i just checked out your inner fender progress for the first time in a while and i have to say they look great.excellent work.
#120 |
Droppin' It Like It's Hot!
Robert
Life Member RIP CAROL JANICE HARTMAN. BELOVED MOTHER. 01/04/53 - 03/05/09 1969 ![]() Norwood, MO 2007 Big Sandy, TN 2008 Had nothing to do with the forklift! Kirkwood, MO (Midwest Meet 2009) Midwest All Truck Nationals, KCMO - 2008 - 2009 - 2010 - 2012 - 2014 SUPPORT THE SITE HERE! |
#121 |
lookin good!
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
#122 |
67cheby
thanks maybe we should get a set for your truck !!
#123 |
Yer keepin' her a 6 lug!
#124 |
if you were closer i would be over in a heart beat.or you could just fly me down,i could use a vacation haha.
#125 |
thanks man.just checked out your builds.you guys have some skill.to bad i didnt know you when i was living out that way.
