05-19-2011, 07:33 PM | #126 |
Re: Project...praise the lowered
maybe after i get all the bugs out.for now i bought some trailer fenders im going to tack in place
check out my build (the start of a shaved,channeled,bagged 67 gmc with a 01 gmc frame and drivetrain) http://67-72chevytrucks.com/vboard/s...d.php?t=434253 |
05-19-2011, 07:38 PM | #127 | |
05-19-2011, 07:40 PM | #128 |
almost forgot.more goodies in the mail.compressor ,pressure switch and got some locking lug nuts.
05-20-2011, 10:26 AM | #129 | |
Raymond 1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper. My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594 The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939 Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402 |
05-20-2011, 08:06 PM | #130 | |
haha.a buddy of mine reminded me that the newer style rear end will be weider then the old.i will get a measurement on sunday
05-22-2011, 07:53 PM | #131 |
from face to face of the newer style rear end is 68 inches.old rear end is 62 1/2 inches.quite a difference. but now everyone knows.
today me and my girl finished stripping all the crud off the rear half of the frame.ground off all the welds from the stuff i cut off,then primed and painted with box liner.turned out perfect.then i got the front suspension (minus the bags) installed and tonight i threw a couple wheels on and dropped her down.its going to lay real nice.should have the rear axle mocked up tomorrow.finally we have some nice driveway working weather.
05-22-2011, 07:58 PM | #132 |
67cheby
so you are putting your truck on the new body frame ??
05-22-2011, 08:02 PM | #133 |
yup.67 on the newer frame.using as much as i can from the newer truck.motor/trans/wiring/most of the suspension/wiper motor/steering column/gauges/air conditioning eventually ect and pretty much the complete body from the 67
check out my build (the start of a shaved,channeled,bagged 67 gmc with a 01 gmc frame and drivetrain) http://67-72chevytrucks.com/vboard/s...d.php?t=434253 Last edited by (joey); 05-22-2011 at 08:03 PM. |
05-22-2011, 08:08 PM | #134 |
Looking real good, Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
05-22-2011, 08:12 PM | #135 |
67cheby
oh thats cool man
05-23-2011, 07:39 PM | #136 |
another good day for the driveway build.today i mocked up the rear end.me and the mrs got the wheel base with in an 1/8th first try.after we got it perfect i got the control arms measured and marked out where im going to build the rear bag mounts/axle pads/and u bolt mounts.after going out for the afternoon i cut up some box sides when i got back.from long box to short box.it wasnt a bad job at all.
05-23-2011, 07:41 PM | #137 |
low n' slo
so are you gonna make a bracket that bolts to the axle to hold the link bar? or are you going to weld it to the axle?
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
05-23-2011, 07:51 PM | #138 |
PROJECT 7DEUCE
Looks like you could get away with the u bolts possibly??
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
05-23-2011, 07:53 PM | #139 |
im going to use some of the stock mounting hardware from the newer truck setup.in the first picture you can see one of the axle pads under the u bolt.its what kept the axle flat on the leaf springs.where the leafs sat on top of the axle i cut it off and im rotating them around to the bottom to sit on top of the arms.in the top left of the same pic you can see some more u bolt mounting brackets.im going to set that on top of the axle and drop the u bolts through a couple of brackets im going to weld to the arms.hard to explain but i will post a pic as soon as i get it done
05-23-2011, 09:29 PM | #140 |
low n' slo
nice. im likeing that setup. are you mounting your bags on the bars behind the axle?
i wonder if i could make something like this myself for my truck that would just bolt on...
05-23-2011, 10:13 PM | #141 |
That front clip looks amazing, nice build.
1968 chevy lwb, getting ready to join forces with the 70 gmc 1970 gmc swb, getting ready to be a 68 chevy swb 1971 gmc lwb 2500 2wd Sierra Grande 1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins |
05-24-2011, 05:45 PM | #142 |
as always thanks for the input.
Kev im sure you could do something like this setup.and the bags are going to mount behind the axle.i made some bag mounts and u bolt mounts today at work.i should have the arms finished tomorrow.i will post a pic as soon as i can.today i did a little more blocking on the dash.about another hour and it should be ready for primer.after fitting up the gauge cluster i discovered i have to re bend the mounts a little.not a big deal.i also snaped a pic of the paddle valve setup and gauges.hides most of the seam where the dash meets the console real nice.
05-25-2011, 05:31 PM | #143 |
i got the rear arms complete.minus the paint and shock mounts.after i set my ride height this weekend i should be able to make the upper bag mounts.
05-26-2011, 08:24 PM | #144 |
i had a little over sn hour of spare time to work on the ol girl today so i installed the shifter and the parking brake.a little more metal shaping and the console will be ready for fill.
05-26-2011, 10:31 PM | #145 |
67cheby
looking good man !!
05-27-2011, 12:07 AM | #146 |
VA72C10
nice work!
Looking for a 67-72 swb or blazer project in or around VA. |
05-27-2011, 11:23 AM | #147 |
i'm loving the lines of that console!
06-05-2011, 03:26 PM | #148 |
sorry for not having any updates for those of you following.i have been quite busy with the build and enjoying the summer.so here is where i am now.drivers side box is now one piece,welded together,wheel arch patch in place,body work done including hours and hours of blocking (had some help from the build foreman),epoxy primed and high build primed.brake lines are all built,bent,just need flared.abs heart is cleaned,painted and ready to go.and now in the works is a custom stainless fuel tank to take place of the stocker from the newer donor truck.when i moved the rear axle ahead 4 inches it was hitting the rear of the tank.heres some pics of the build and a couple trucks from a car show i went to yesterday.
06-05-2011, 03:30 PM | #149 |
67cheby
nice work and COOL
06-10-2011, 05:04 PM | #150 |
67cheby im going to have to get you a number 1 fan t-shirt haha
after blocking and sanding for the past week i managed to do some paint and primer.the dash didnt turn out too bad for combining the newer gauge housing and playing around with a little sheet metal.feels good to spray a little color.
