Old 05-18-2011, 03:27 PM   #1
Low87
been here longer than Liz
Low87's Avatar
Question 87-91 Blazer ?s
I'm looking at selling the '98 GMC and going for an 87-91 Blazer. My only experience with these was the '77 rust bucket I owned for about a month many years ago. So, before I get to looking too much I've got some questions based on ads I'm seeing.
Do all 88-91 have the newer 4 lamp front end? I'm seeing some listed as that year that have the 81-87 setup instead.
Do all 87-91 come with TBI? I see some that have a carb instead, which makes me worry about a botched swap.
Any other tips would be appreciated. Probably have more questions later.
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 05-18-2011, 04:09 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 87-91 Blazer ?s
All 87-91 blazers/burbs should be fuel injected from the factory.
The better optioned 89-91 blazers/burbs came with the 4-headlight set-up,... or a cheaper 2-light set-up on the low optioned blazers/burbs.
Keith
Convert to disc brakes.
Old 05-18-2011, 04:20 PM   #3
Jonboy
Slots go on anything!
Re: 87-91 Blazer ?s
Keith is right on. The later ones (after '86) also got reclining seats finally, and most will have overdrive.
You might also look at Suburbans, too. There are quite a few down here. They did get a lot better with the rustproofing post '81 as well.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 05-18-2011, 04:28 PM   #4
Low87
Low87's Avatar
Re: 87-91 Blazer ?s
Thanks guys, that helps. Might have a few to look at.
I'm not ready for a Burb Jon. I hate parking the xcab GMC as it is, can't imagine piloting a Burb.
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 05-18-2011, 04:33 PM   #5
Jonboy
Re: 87-91 Blazer ?s
The 'burb is about the same as your pickup, for the most part. Just don't parallel park, and you are all good.
Old 05-19-2011, 01:15 AM   #6
pmpski_1
pmpski_1's Avatar
Re: 87-91 Blazer ?s
I bought a 91 a month or so ago and had quite a few questions. There is some great info in this thread:
http://coloradok5.com/forums/showthr...ight=love+hate
pmpski_1 is offline   Reply With Quote
Old 05-19-2011, 11:22 AM   #7
Low87
Low87's Avatar
Re: 87-91 Blazer ?s
Good link pmpski_1, thanks.
And from what I've seen over the past couple days (including the LMC catalog if that's a reputable reference), '88 has the same grill as the '87. In '89 it changed to the newer look. That's different than what I've always thought.
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 05-20-2011, 12:31 AM   #8
pmpski_1
pmpski_1's Avatar
Re: 87-91 Blazer ?s
You're welcome. One guy was talking about the 89 being a great year because of the serpentine belt but having a mechanical speedo, or something like that.
I was torn between the full convertible or the TBI. In the end, most of the full convertibles I looked at were more work than I wanted.
I actually ended up with a GMC Jimmy, so I can't help with the Blazer grill questions
Old 05-20-2011, 09:16 AM   #9
Low87
Low87's Avatar
Re: 87-91 Blazer ?s
I'm looking at an '89 GMC Jimmy right now too.
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 05-20-2011, 09:23 AM   #10
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Re: 87-91 Blazer ?s
They will be TBI or 6.2 Diesel. 88 did still have the 87 grill.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 05-21-2011, 12:41 AM   #11
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: 87-91 Blazer ?s
Yea '87 and up should all have TBIs or 6.2s so any carbed ones would be swapped in. I like the '90 I used to have '89 aint a bad year either. They only problem I ever had was lifting it and cracking the frame where the steering box hooked up!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 05-25-2011, 06:51 AM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
Re: 87-91 Blazer ?s
yup both my 87 and 88 burbs had the older 4 eyes setup
my 89 has the newer 4 lights
FI was factory in 87 Keith got me straight on that(or somethings up)
but i thought the 2 light setup was early 80s?
and the 89 had the vss speedo
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
