drip rail question
I was wondering what the best caulking is to use on the drip rail. What have you guys used, and what works best as far as sealing out water?
Re: drip rail question
I have actually used jb weld once. There was some rust through, and i couldn't get in it to weld and grind so i cleaned it out and put some jb weld on with my finger. When it was painted you couldn't tell.
Senior Enthusiast
I use JB Weld for everything so I’m a firm believer in that approach, if it’s what you need. Post #3 on this thread shows how I did my rain gutters:
http://67-72chevytrucks.com/vboard/s...ht=seam+sealer Evercoat Maxim self-leveling sealer. The nice part is it can be applied with a standard caulking gun Last edited by markeb01; 05-18-2011 at 02:57 PM. |
The local body shop uses some brand of seam sealer.
1963 Chevy stepside 327 1965 Chevy swb 383 1996 Mystic Mustang Cobra 2009 Pontiac G8 GXP 415hp/415tq 6speed |
I used 3M self-leveling seam sealer
Who Me?
Are you guys actually filling in the drip rail or just sealing it?
Did these ever have a drain hole somewhere in it? Mine doesnt.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
My 66 has four small slots for draines. Two on each side. One at the rear and one towards the front right before it curves around to the windshield.
Airport Bum
1964 Chevrolet C-10 1941 Chevrolet coupe 1962 Thunderbird 1959 Edsel Villager 1963 Skylark |
Who Me?
I thought I remembered seeing them on my 65, but they are filled on my 61.
#10 | |
![]() Join Date: Mar 2005
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
I whittled a paint stick to put into the drain holes, then removed them after the seam sealer set up to keep the drain holes open. Worked fine.
I used Fusor Self Leveling seam sealer on my '65 resto project. Its an epoxy so no shrinking and cracking later on. Its sandable if you need to touch up a spot. Let it cure, scuff the sealer with a grey 3M pad, and shoot your paint on top.
60-66 Nut
What does the gun cost for that cartridge? The 3M guns are around $100.....
#14 | |
I'm not sure on the cost of the gun. My dad owns a glass shop and a sales rep gave him a pnuematic dual-mix gun like the one in this vid: |
#15 |
There were two factory pinch holes toward the back of the rail, where it tend to angle upward. I had the guys close mine and the painted ran seam sealer all arouns the bottom where the roof panel meets the top of the cab. Since th etruck will be 90% show and 10% crisue she probaly won't see much rain. LIke many, I'll keep a few towels and pat her down before and after the rain.
http://s1299.photobucket.com/user/jb...23904108567829 |
#16 |
I did a google search, a SEM brand dual mix applicatioin gun cost around $60 bucks. The pnuematic guns run around $300.
SEM gun: http://www.autobodytoolmart.com/sem-...9-p-15587.aspx Pnuematic: http://www.autobodytoolmart.com/sem-...9-p-15586.aspx To keep the drains open, I rolled up wax paper into a cone shape and slid that into the drain holes before I applied the seam sealer, then took the wax paper out once it had cured. Last edited by theastronaut; 05-19-2011 at 12:23 PM. Reason: fix link |
#17 |
Anybody have pics of the drains after sealed?
#18 |
I also used the 3M self leveling seal sealer. THe paint supply place lent me the double barrell caulking gun for a $40 refundable deposit. Call around, no reason a place can't lend it to you for a few days.
#19 |
I have a couple at work I think I could borrow it for the weekend as long as I bring it back!
#20 | |
60-66 Nut
So the SEM gun will work with the Fusor cartridges? The SEM gun says it is for 7oz cartridges, and the Fusor cartridges I find online are 10.1oz.
#21 |
With a MIG welder & some time a regular cheap caulking gun can be converted to pump most all of these seam sealers-most are proprietary-you must use this gun w/this brand sealer-but if you're poor(like me) & cannot borrow one, it can be done fairly easily.
Most guys cut off the end of the caulk gun & weld on a double barrel setup, sized to the sealer tubes-I've seen old 3/8 drive sockets used, flat washers, you name it |
#22 |
I just checked the pneumatic gun we have at the shop, and its a Cox brand. It know it works with fusor cartridges but at the moment I don't have any SEM cartridges to check and see if they'll work. I think the difference in the SEM and Fusor tubes are the length?
