Old 05-13-2011, 05:43 PM   #1
Luvlegs
Luvlegs's Avatar
Seam sealer set up time... ever????
I used the 3M seam sealer (not the mixed epoxy, just the caulk tube version) - let it set for 24 hours (says it's ready to paint in 40 minutes...). Touched up a few areas - sanded a bit here and there and did a little more skimming to make it nice. I then waited ANOTHER day and primed/painted - 7 days later... LOOKS fantastic - FEELS "mushy". The paint feels tacky - almost like you could leave a finger print in it. 10 days later, out of my shop now but under a covered pole barn, it feels firmer but like a fingernail would dent it. Just curious if anyone else has seen this or might know the issue.
I ADDED SOME PICS AT THE END
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 05-13-2011, 09:52 PM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Seam sealer set up time... ever????
hey D....are you making this up??? You know you cannot post this without pictures
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 05-14-2011, 12:53 AM   #3
treveiger
treveiger's Avatar
interested also
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 05-14-2011, 01:06 AM   #4
ace of shades
NEWBIE!!
ace of shades's Avatar
I has been a while since I have worked with seam sealer, but I do remember there are some products out there don't fully "cure" or get hard, hard. I don't remember off hand what the soft set seam sealer is used for but I have ran into the problem of grabbing the wrong tube and having to start over on some projects. If its not the soft set style, it might just be on too thick. I personally think If it was that think it wouldn't have stayed on the panel
Water is for the weak
I don't like cocaine.. I just like the smell of it
"Well there might be a dime up a goats ass too, but I ain't looken" - Grandpa
VolksRods
ace of shades is offline   Reply With Quote
Old 05-14-2011, 11:09 PM   #5
danman987123
danman987123's Avatar
no....we use seam sealer all the time at the shop...same 3m one also....it stays soft for a log time but dont worry....as long as u dont dig ur nails into like u said there wont be any marks....it just seems soft for a long while but u can still paint it and it dries like normal just stays a little soft but dont worry it will be fine
danman987123 is offline   Reply With Quote
Old 05-15-2011, 03:20 PM   #6
Luvlegs
Luvlegs's Avatar
AWESOME!!! I REALLY didn't want to redo it.
1972 C10 L6 3OTT
Old 05-15-2011, 04:03 PM   #7
Luvlegs
Luvlegs's Avatar
Doesn't look so good in pics... I wonder if I should have put it on thicker so it didn't show the waves of the metal... What I took out was like 1/2" thick - anyone think I should redo it and go "deeper" with the sealer?
1972 C10 L6 3OTT
Old 05-15-2011, 08:04 PM   #8
tjvending
tjvending's Avatar
Did you cover it im primer after you put in on or straight to painting?
tjvending is offline   Reply With Quote
Old 05-15-2011, 09:43 PM   #9
MistaGavin
MistaGavin's Avatar
Are you supposed to prime then apply the sealer or prime after you put it in?
You're not old, it IS loud!
1970 CST-10 BB 400
MistaGavin is offline   Reply With Quote
Old 05-16-2011, 06:18 PM   #10
Luvlegs
Luvlegs's Avatar
I put it on bare metal and THEN primed it.
1972 C10 L6 3OTT
Old 05-16-2011, 08:36 PM   #11
leddzepp
Moderator
leddzepp's Avatar
What is the 3M part number of the seam sealer you used?
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-16-2011, 09:08 PM   #12
CaptRMW
Custom Sport W/T
CaptRMW's Avatar
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
It looks and sounds like 3 M "Fast and Firm" and the firm part is misleading. Not a bad thing as it needs to be a little flexible but you are right as it takes a long time to set. I used it over primer and had to take it out and grind to bare metal. Rubber glove and Zylene will smooth it pretty good but work fast as it will tack in short time...Roger
CaptRMW is offline   Reply With Quote
Old 05-16-2011, 10:20 PM   #13
danman987123
ya the 3m fast and firm is a good product it comes like in a blue and white tube.....he is right up there ^....just put a glove on....after it has been sitting for a while dip ur finger in some kind of solvent....even a bit of paint reducer works well just to smooth it out really nice....but let it sit for a bit....maybe 30min or so that way it is a little firmer and will smooth out nicer.....good luck
Old 05-16-2011, 10:35 PM   #14
Luvlegs
Luvlegs's Avatar
I used the sealpro 08300. I edited my previous post - not sure why I got it out of order but I put it on the bare metal and THEN I primed.
1972 C10 L6 3OTT
Old 05-21-2011, 08:21 AM   #15
Luvlegs
Luvlegs's Avatar
It's been a while since I first posted this so I'll TTT - still curios if it looks like I have enough in there or should I add more? I can't say I've ever seen an original so I don't have anything to judge by. Thanks all.
1972 C10 L6 3OTT
