![]() Join Date: Feb 2011
Hey,...
I would need some advice and opinions on some parts I would like to buy for my built up. I have a 64 C10,... It will have an LS1 with 4L60e transmission, and a drop kit from Nate. Steering Colmn: ididit or flaming river? I want to have a tilt column shift sttering column, witch do you recommend? I had a look at his one here: http://www.summitracing.com/parts/IDT-1140650010/ Harness: What complete harness for the dash do you recommend? Radiator: I have in my other cars BeCool and really like the quality they built, what is an alternative for a radiator with transmission cooler built in? Gauges: I found some dash gauges kits at bay... is there any other place to buy from or any other ideas? http://cgi.ebay.com/ebaymotors/64-66...#ht_2955wt_796 Thanks for your help! Fabian |
Re: need advice on parts for my built up,...
You can make that dash for a heck of a lot less. There is nothing to it, just get a set of gauges, make a plate for mounting and be done. There are lots of great dash builds on here.
I am using my stock gauges with a white face kit and some custom vinyl lettering. For wiring, I am using a universal 21 circuit kit with mini fuse box.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
![]() Join Date: Aug 2004
I would recomend this, unless you just like those columns and or spending the $
http://www.classicperform.com/Store/...6772EPSC-S.htm Harness, if your replaceing the entire harness, I recomend American Auto Wires Hiway series. has all the plugs and grometts I use Dolphin guages with the Boese engineering dash panel http://cgi.ebay.com/ebaymotors/64-65...item45faa94ec9 I hope this helps, good luck and BTW we here are picture hoes, can you feed the need please?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
I don't know your time frames, but avoid buying anything your not going to install right away. I have lost money a number of times because I bought a bunch of parts to either save shipping or to get the parts while I have the money and then in as little as 3 monthsi can't send back a bad or non fitting part. I have items I can't use from CPP (sent wrong pitman arm), MAR-K (damaged), and Tuckers (don't even want to talk about that mess). I didn't answer any of you questions, did I.
1963 Chevy stepside 327 1965 Chevy swb 383 1996 Mystic Mustang Cobra 2009 Pontiac G8 GXP 415hp/415tq 6speed |
#5 | |
#6 | |
Just for info we offer a direct fit aluminum radiator for $280.00 on sale right now. Make / Model Chevy Truck Year(s) 1963-66 Engine All, Exc L6 230 Material Aluminum Available Cores High Efficiency Aluminum Core Size 17-1/4 x 25-1/2 Available Rows 2 Cooler Size 12-1/2x1/4 NPT Flow Type Downflow Inlet Size 1-1/2" Outlet Size 1-3/4" Last edited by mbgmike; 05-20-2011 at 06:52 PM. |
Ididit not Flaming, you have the right part. Becool had one good but not worth their price. For the price of some of their radiators you can buy so many other parts and still get a great radiator. Becool in Germany or Switzerland- overkill, I live in central Arizona, Google it, gets much hotter here - radiators we know. Gauges so many... If you would like an American iconic look try Mooneyes or So-cal both have their own name brand guages. Tschüs
