Old 05-22-2011, 06:45 AM   #1
LONGHAIR
Re: Will these gears fit a 67 c10 rear end
Originally Posted by gysgtc View Post
12 bolt 4.10 Positraction rearend out of a 1967 Chevy G-10 van. Thanks. Wayne
Are you asking if the entire housing will work? or just the internals? Messing with used gears is almost always a big problem. It really requires a "Pro" and most of them will not touch it....
Originally Posted by Jeffs70 View Post
I Tried to switch the carriers a few days ago from two rear ends to make a good posi rear end. I also changed the pinion and ring gear but then one rear end worked fine with the posi carrier. but the other did not fit so well after. there is to much pressure on the ring gear and pinion even with no shims so you may want to check your carriers before hand and I noticed the area where the ring gears bolts are, there is more tappered and pushes the carrier more the other way and keeps it offset to much.
You must have 2 different "series" of carriers.....they will NOT interchange. It is very likely that you now have two un-usable rear ends.
There is a lot of precision involved in setting up a ring & pinion set.
Anyone can throw the correct pieces together and make them turn....but that's a lonnng way from being correct and it absolutely has to be. If it is not perfect, it will be noisey and fail in a very short time.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
