#1 | ||
Re: Rearend
While the above "Copy & Paste" is accurate, most of it is irrelevant.... The only one of those adjustments that can possibly change with a pinion seal install is the pinion bearing preload.....and it takes a lot more torque than you would think to crush the sleeve. None of the rest of those details matter at all in this case. If they are already wrong, there is nothing that you can do about it now anyway. Pop the yoke off, swap the seal, and put it all back together. Torque the nut to about 75 ft-lbs with red Lock-Tite and run it. That is plenty of torque to keep the nut tight and not nearly enough to crush the sleeve any more. The whole in-lb "rotation" thing is based on a completely stripped housing, no carrier, axles, or seal.....and that is for new bearings. Used are going to be looser anyway....and it is not advisable to "mess with" trying to tighten them up. The real issue here is that you may already be "too late". If the pinion seal is leaking, the bearings may already be shot....which kills the seal in the first place.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
