Old 05-16-2011, 01:49 PM   #1
Huggerorangeblood
33 X 12.50- 15 on a stock blazer? Any thoughts and pictures?
I have stock ralleys on my blazer and want to go to a weld super single like my pickups. Do I need a lift to go to 33's or will it work? thanks, eric
Huggerorangeblood is offline   Reply With Quote
Old 05-16-2011, 03:33 PM   #2
JWPOORE
Re: 33 X 12.50- 15 on a stock blazer? Any thoughts and pictures?
I have that size tire on my 70 Blazer and they are fine, no lift and no problems with them at all.
JWPOORE is offline   Reply With Quote
Old 05-16-2011, 03:45 PM   #3
bigdon-70blazer
That is close top size on my blazer, 33 X 12.50 - 16.5
bigdon-70blazer is offline   Reply With Quote
Old 05-16-2011, 09:32 PM   #4
dubds10
Stalker Nate
33 x 12.5/17 .... not the same size but overall same. Mine's got a 2" lift in the rear though. Front is all original springs which might have a little sag in them. They rub on full lock, but otherwise turn and work great.
Nate
1957 GMC SWB stepper modified summer time driver
1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project
1965 Chevy P10 Ice Cream Truck project
Instagram - TheDonutDiner
FaceBook - @UscreamIscream
dubds10 is offline   Reply With Quote
Old 05-21-2011, 07:36 AM   #5
legendary
legendary's Avatar
That green blazer is very nice!
Best Regards,
Leon
1970 C/10 LWB Cummins Turbo - Build in Progress
Many other toys as well...
legendary is offline   Reply With Quote
Old 05-21-2011, 08:37 AM   #6
72gmguy
72gmguy's Avatar
I had 33x12.5s on my blazer but they rubbed at full turn. I have since done a 2 1/2 inch lift and it works great now.
Jeremy
1969 Blazer 4x4 original cst
1971 Blazer partial 2wd convert
1972 Blazer 4x4 original cst
1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper
1970 4x4 suburban w/ 6in lift and 35in tires
1968 Corvette convertible
1970 Malibu convertible
1959 Brookwood wagon
1972 International Scout ii
72gmguy is offline   Reply With Quote
Old 05-21-2011, 12:46 PM   #7
mustardjimmy71
toys'r'us
mustardjimmy71's Avatar
Thats probably due to your offset. With stock rallies 33 12.50 15 fit fine
71 jimmy bone stock 350 sm465 33x12.5 rallies
79 caprice landau full load crate350 th350 lowered 20"wires
00 f150 reg cab sb 4x4 5.4L
mustardjimmy71 is offline   Reply With Quote
Old 05-21-2011, 05:13 PM   #8
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
FYI, Rallies did not come stock on 69-72 Blazers, but they do look great.
Also, each brand of tire has a different overall height. I'd measure your current tires and the clearance at full turn and see how much space you have. Then check with the manufacturers to see what the true height is of their tires.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 05-21-2011, 10:05 PM   #9
Huggerorangeblood
I purchased a set of weld super single 15X10 wheels and the 33X12.50 tires. The wheels rub on the calipers to the point of locking the wheels if I tighten them down and I think the wheel might touch the tie rod end too. Very frustrating. Haven't been to the shop since. Any ideas? Thought about spacers but that could cause other problems.
Old 05-23-2011, 12:51 PM   #10
ZZ4
Let me know if you want to sell your super singles that the exact wheel im looking for. Thanks
ZZ4 is offline   Reply With Quote
Old 05-23-2011, 02:42 PM   #11
bouncytruck
SKINNY TIRES RULE!
I have heard that with some of the newer wheels, you need to have the centers machined larger to have them fit over the older hubs. Not sure if that is your problem or not though.
bouncytruck 1972 K5
