Old 05-24-2011, 10:59 AM   #1
yellowGT
yellowGT's Avatar
windows wont roll up
The only way they go up is if I hook up a battery directly to the window motor. If I hook them up to the window harness they wont roll down or up. Everything seems to be plugged in. Any pointers?
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
'89 chevy crew cab dually 3+3
yellowGT is offline   Reply With Quote
Old 05-24-2011, 11:08 AM   #2
Low87
been here longer than Liz
Low87's Avatar
Re: windows wont roll up
Check the wiring inside the boot between your door and door jamb. Years of opening & closing eventually wears the wiring out. Might be cracked inside the rubber sheath.
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 05-24-2011, 11:40 AM   #3
DesertCat
DesertCat's Avatar
Or your relay may be toast. Check if you are getting switched input/output there. If it is bad, I have an NOS one that I'd let go reasonably cheap.
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131
DesertCat is offline   Reply With Quote
Old 05-24-2011, 12:19 PM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
yup check the wires ,mine acted up and I went manual
the wires crack inside the tube
(this method of access not recomended) lol
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
