Old 05-24-2011, 01:38 AM   #1
Tim R
speedo cable
Does anyone know where I can get a speedo cable for a 700r4 to the stock dash ?
Tim R is offline   Reply With Quote
Old 05-24-2011, 08:34 AM   #2
chevykevy
chevykevy's Avatar
Re: speedo cable
You should be able to use the same cable you have unless it is short. If it is too short, you just need to get a longer cable. Look at LMC, they offer 3 or 4 different lengths.
Unless your 700r4 is an electronic speedo, you can use the stock cable.
I did.
chevykevy is offline   Reply With Quote
Old 05-24-2011, 10:00 AM   #3
Tim R
Re: speedo cable
COOL thanks wasnt sure if the end was the same and my 700 is the older one with a geared speedo drive
Thanks Tim
Old 05-24-2011, 04:17 PM   #4
cdowns
cdowns's Avatar
Re: speedo cable
available with no shipping costs at local autoparts stores
Old 05-24-2011, 07:32 PM   #5
Tim R
Re: speedo cable
Yep went to oriellys and we found an 80 inch pioneer speedo cable worked great was able to go over the frame rail and miss the exhaust with the extra lenght . My exhaust is tucked up and goes through the trailing arm frame rail
Thanks for the info
