Old 05-24-2011, 12:48 AM   #326
gringoloco
A guy with a truck
gringoloco's Avatar
Re: How to: Ruin a perfectly good C10
Got a little done today in the way of installing the fuel filler- ended up having to shorten the fill tube to keep a downhill slope from the filler to the tank. Using the late model door also left me with a nasty-looking protrusion into the bed. I used part of a formed metal blister to cover the ugliness- I think it turned out 'good enough'...
Also painted the tailgate, filler cover, filler door, and the rear of the bed. I had to do something with the area at the tailgate where the wood ends. A wood floor cross-sill would have a step-up here; I used a piece of 1.25" angle iron as a suitable substitute
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
Sporadically present, non-dues paying member of the world-famous Louisiana Classic Truck Club (LCTC).
gringoloco is offline   Reply With Quote
Old 05-24-2011, 12:52 AM   #327
Riveted1
Tasty Cakes!
Riveted1's Avatar
"Good enough" That looks great man!
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 05-24-2011, 01:13 AM   #328
gringoloco
A guy with a truck
gringoloco's Avatar
While I was waiting for paint to dry, I also got busy putting the front of the truck back together. I installed the bowtie and hood latch and started making one good grill out of the two that I have.
I used the insert from the aftermarket grill that was on the truck, painting it flat black, then removing the paint from the louvers, to resemble a factory 1970 inner grill, instead of a '69, like all repop inners. Did you know there are 60 'louvers' on a '70 grill? I do now... I had to detail each and every one of them today, but the effort was well worth it. The outer still needs a good cleaning, but it's starting to look like a truck again- that actually says 'Chevrolet' on it
-Chris
Old 05-24-2011, 01:16 AM   #329
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks for the positive comment. I would have liked to butt weld it in flush and body work it, so that it looks like it came that way, but time does not permit. The rivets are kinda cool looking anyway
-Chris
Old 05-24-2011, 01:41 AM   #330
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Looking great! I may just have to copy you on the raised floor, it is turning out awesome and it would get me a little lower.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 05-24-2011, 07:50 AM   #331
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
I think JUST IN CASE its prolly better that you can remove that cover... never no why ya may need to access through there....
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 05-24-2011, 09:54 AM   #332
67cheby
67cheby
67cheby's Avatar
if you would like me to ....i will keep the truck company while your gone...we dont want her getting lonely now do we ???
67cheby is offline   Reply With Quote
Old 05-24-2011, 09:56 AM   #333
VA72C10
VA72C10
VA72C10's Avatar
Great job on the inner and the fuel cover! Are you going to detail the outer as well (black lettering)?
Old 05-24-2011, 01:36 PM   #334
gringoloco
A guy with a truck
gringoloco's Avatar
Certainly! I have gotten TONS of ideas off the boards. I can only hope to give a little back
True, ya never know...
Haha- she won't be lonely long- fiance wants a '67 fastback
Thanks, and yes, I will be detailing the outer, but for now, I'm just trying to get 'er going
-Chris
Old 05-24-2011, 11:57 PM   #335
gringoloco
A guy with a truck
gringoloco's Avatar
Daily update: While the inner fenders are out, and the doors disassembled, I took the opportunity to drill a bunch of holes down the side of my freshly painted truck
Started with a piece of 2" tape, for reference, then marked and drilled for the lower body side molding. Went pretty smoothly other than having to peel some woodgrain tape (the sun helped a lot) and trimming the rear-most pieces from long bed trim. I'm not totally sold on the look, but I've definitely bought it, as there's no turning back now...
Also put the guts back in the doors including new window regulators and chrome vents, and re-installed the windshield by myself! I was a little apprehensive, having heard horror stories of people breaking the glass and having to buy new, but I went for it and it slid right in. Took me about a half hour and very few choice words
-Chris
Old 05-25-2011, 12:38 AM   #336
67chevy1series
67chevy1series's Avatar
wow you got your window in by your self? that is a night mare.... been there done that...right as mine when in to its final setting place it had a crack right in front of the drivers seat!!!! i had very few choice of words to
67chevy1series is offline   Reply With Quote
Old 05-25-2011, 01:19 AM   #337
lolife99
67-72 parts collector,…
lolife99's Avatar
Great job on the lower trim.
Did you have a set of instructions for drilling all the holes?
I have a truck I want to add lower trim to also.
Keith
Convert to disc brakes.
Old 05-25-2011, 08:18 AM   #338
gringoloco
A guy with a truck
gringoloco's Avatar
Yikes! That's what I was afraid of- guess I got lucky
Yup- found 'em in the FAQ: http://67-72chevytrucks.com/vboard/s...d.php?t=221881 Though I found it easier to use a piece of 2" tape on the body line for height measurements, placing the holes CL about 2 1/8" down from the 'crease'. The fore/aft spacing is not as critical, since the clips are adjustable within the trim. There is also a bit of adjustment, due to the holes being slightly larger than the studs. It was really pretty easy once I got past the shock of drilling into my fresh paint...
-Chris
Old 05-25-2011, 11:40 AM   #339
Chitown_hillbilly
Chitown_hillbilly's Avatar
Ya know people like you and your ability to to do top notch work at a break neck pace make me sick... nothing personal I'm just jealous (of both your abilities and your truck).
Chitown_hillbilly is offline   Reply With Quote
Old 05-25-2011, 12:09 PM   #340
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
I am about to put on the 4.3 serp set up on my 350, what powersteering pressure line did you use?
Are the newer styles metric fittings in the pump or what?
Smitty
71 C10 283/3SPD Full Resto
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me https://67-72chevytrucks.com/vboard/...d.php?t=841215
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 05-25-2011, 02:39 PM   #341
lolife99
lolife99's Avatar
Thanks for the link!
Keith
Old 05-25-2011, 03:23 PM   #342
gringoloco
A guy with a truck
gringoloco's Avatar
Haha- thanks! I learn by doing- what you don't see is all the stuff I screw up, or how much my other responsibilities get neglected. I can only do this for short bursts...
Smitty
Two ways to attack it: use a late model steering box and hose (what I did, needed a rebuild anyway) or use the old style fitting in the new pump. It is, I think, 1 1/8" fitting that swaps directly. I'm pretty sure they're actually the same pump, just with different resevoirs.
No worries; I'm sure you've helped me out at least once before
-Chris
Old 05-25-2011, 05:19 PM   #343
71meangreenc10
Thanks for the info GL......
Smitty
71 C30 Wrecker
Old 05-25-2011, 06:08 PM   #344
tommyd241
tommyd241's Avatar
Wow! What an amazing build and beautiful truck! Subscribed!
'68 SWB Fleetside
'98 K1500 Silverado
tommyd241 is offline   Reply With Quote
Old 05-25-2011, 09:37 PM   #345
mcbassin
Still Learning
mcbassin's Avatar
Super fast progress!
Old 05-25-2011, 11:27 PM   #346
gringoloco
A guy with a truck
gringoloco's Avatar
Smitty
No prob!
Thanks a lot! I actually drove it some today and got lots of attention...
Almost 'done'
-Chris
Old 05-25-2011, 11:46 PM   #347
gringoloco
A guy with a truck
gringoloco's Avatar
Not much of a picture day, but good progress nonetheless. I started by taking the front wheels and tires to get mounted this morning. I put the tires on powdercoated 7" rallies, instead of the 6.5" van wheels and it bought me the clearance I needed at the lower control arm. It turns beautifully and the inner wheel weights actually stay on
Once the wheels were back on the truck, I drove her over to the local alignment shop and had it lined up. They also charged the A/C system for me and it blows nice and cold The guys there loved the truck- couldn't stop asking question and giving compliments- even had one of the 'old heads' give me kudos on the front suspension rebuild, and thanked me for leaving the inner fenders out for him to get to the alignment shims.
Also finished installing the rest of the body side molding and tailgate and taillight trim (anyone have a spare amber marker?), then had a terrible time glue-ing the passenger door weatherstrip in- what a pain! NOT looking forward to doing the driver's side. More choice words than used on the windshield install...
-Chris
Old 05-26-2011, 06:49 AM   #348
Bennett68C10
Bennett68C10's Avatar
truck looks great and came together fast
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 05-26-2011, 02:31 PM   #349
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks! Should be mostly together today
-Chris
Old 05-26-2011, 04:56 PM   #350
Houch
Time Machine
Houch's Avatar
Beautiful truck. Your doing an awesome job. I had just about wrote my cab off but your windshield repair inspires me to repair it. Keep up the inspiring build.
Greg
1970 Chevy SWB
http://67-72chevytrucks.com/vboard//...d.php?t=390588
Houch is offline   Reply With Quote
