Old 05-24-2011, 02:05 PM   #1
55metalmonkey
Axle question
I posted this in the suspension section but to no avail. any help would be appreciated
http://67-72chevytrucks.com/vboard/s...04#post4697804
55metalmonkey is offline   Reply With Quote
Old 05-24-2011, 03:22 PM   #2
01spirit750
Re: Axle question
From the pictures it looks identical to the 1979 Cadillac Seville rear end I used in my truck.
The 78 and 79 Cadillac Sevilles had the truck version of the 10 bolt with a 5" x 5 bolt pattern. They also had the factory disc brakes just like yours.
Try confirming the bolt pattern (5x5 or 5x4.75).
If it is a 5x5 bolt pattern then you definitely have the Cadillac Seville rearend.
GM used the heavy duty rearend in the Sevilles because a lot of these cars came with diesel motors (yes, a diesel caddilac).
01spirit750 is offline   Reply With Quote
Old 05-24-2011, 05:47 PM   #3
55metalmonkey
Re: Axle question
It's 5x 4.75", I probably should have put that in the specs but didn't know caddys would be different. Did you have any of the problems I mentioned even though yours was 5x5? I'm trying to fit at least 10" wide rims
Old 05-24-2011, 08:41 PM   #4
sweet70beast
sweet70beast's Avatar
Re: Axle question
79 and 80 Firebird is my guess if it's 5x4.75. My Nova has this same set up on it from a 79 Caddy. The Firebird and the Caddy disc setup is the same except the Caddy is 5x5 plus the Caddy is coil sprung. Everything between the two seems to be the same, even the rotors except they are drilled the Caddy with the bigger pattern.
I have Caddy backing plates, calipers, master cylinder and prop valve from the Caddy and rotors from the Firebird. This is on my stock 8.5 Nova rear, everything bolted right on.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 05-24-2011, 10:03 PM   #5
01spirit750
Re: Axle question
I am running 15x10's in the back with no problems. It is tight but they ebrake spring clears the rim with no problems.
I had my axles and rotors redrilled to the 5 x 4.75 pattern so all my bolt patterns were the same.
I think you will only have problems if you are running a 14" diameter rim. But I think in your other post you had indicated you were using the much larger rims.
Old 05-25-2011, 01:53 AM   #6
55metalmonkey
Re: Axle question
I'm aiming for 17" rims so I should be good with 10" wide, I just don't want to have to re engineer more stuff, I finnished all my fab work on the frame and most of the other stuff so the major things are going out for media blast this week, I'm just looking forward to assembling things for the last time.
Thanks for the input,
I'll have to see if I can find a set to mock up and check clearance once I get most of it reassembled
Old 05-25-2011, 11:19 PM   #7
mr48chev
mr48chev's Avatar
Re: Axle question
I'm not sure what it is out of but it looks pretty close to the late 70's Firebird rear end I have stashed back for the 48 except for the welded on shock bracket.
All of the 76/79 seville rear ends I have seen have a flange for the driveshaft to bolt to rather than a yoke.
