Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 01-20-2011, 08:13 AM   #1
60ratrod
yes, i do
60ratrod's Avatar
removing water stains from glass?
so my 72 has water stains/marks that don't come off the glass, mostly on the rear window. is there a trick to get rid of those or am i just gonna have to suck it up and buy new glass? the glass on this truck is great, no cracks or broken glass, just the water stains/marks
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 01-20-2011, 08:31 AM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: removing water stains from glass?
60ratrod... check out this link as it might provide a solution to clearing the window before you have to purchase a new one.
http://www.67-72chevytrucks.com/vboa...ighlight=glass
Also, here's a quick search within the Detailing section using "glass" as the search word:
http://www.67-72chevytrucks.com/vboa...archid=2106225
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-20-2011, 08:50 AM   #3
60ratrod
yes, i do
60ratrod's Avatar
hey thanks man. i read the getting scratches out of glass thread and was dreading the possibility of having to use a buffer since it seems to leave depressions and low spots in the glass. i'll look into the chrome polish/cleaner and bar keeper's friend. that's a name i haven't seen since the mid 90's
Old 01-20-2011, 08:53 AM   #4
72BlckButy
Tot Roddin'
72BlckButy's Avatar
"Hopefully" one of thsoe products will assist you in cleaning up the windows, before you have to use a buffer or replace it all together. Let us know what works and what doesn't.
-Nate
Old 01-20-2011, 10:11 AM   #5
60ratrod
yes, i do
60ratrod's Avatar
will do when the weather clears up and i get a chance. glass is back burner for now. i have a driver's floor pan and cab mount that needs replaced asap
Old 01-20-2011, 08:12 PM   #6
kaycee
kaycee's Avatar
I have used the bar-keepers friend on my glass and it is great,I take a green scotch pad and water with a little B-K on it and scrub it down.Then wipe it off with a clean towel,rag etc.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 01-20-2011, 08:38 PM   #7
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
I agree ^^^^^^^^^^^^^
also you can just wipe them with 0000 steel wool....I suck at cleaning windows and this works great..nothing wet just scrub them and you can feel them get claen and smooth
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 01-20-2011, 11:19 PM   #8
60ratrod
yes, i do
60ratrod's Avatar
yeah, but i don't know about scrubbing glass with steel wool though. the greeny weeny i'll do, but the steel wool, that will be a last resort
Old 01-21-2011, 07:27 AM   #9
Hottrucks
Hottrucks's Avatar
the greeenie scares me but the 0000 steel wool islike a cotton bal I even hit the SS around the windows my chrome is kinda ruff (ddstuff) and it keeps that clean too
Old 01-21-2011, 10:54 AM   #10
kaycee
kaycee's Avatar
Ive used both but prefer the pad,steel wool u need to be careful around the paint,chrome, metal, etc.
2005 FXDWG stage3
63 IMPALA 327/4L60
Old 01-22-2011, 12:45 AM   #11
piecesparts
Parts and more parts
piecesparts's Avatar
I have buffed my glass with a polishing compound, like 3M's Finnesse-It and a large buffing wheel and removed water spots.
Frank
Old 02-15-2011, 05:19 AM   #12
PT'S 70 CST
"GO DAWGS"
PT'S 70 CST's Avatar
I second the 0000 steel wool. I have used it several times and as piecesparts said, I buffed it afterwards with Finnesse-it or mirror glaze #2 fine cut cleaner.
PT
70 CST SWB
70 NOVA
93 Indy 500 Pace Truck (SOLD)
94 SILVERADO SWB 5/7 drop
2000 Silverado swb
2005 Nissan Altima 3.5 (Surprisingly very fast)
2004 GMC Yukon XL Denali
BATESBURG, SC. 29006
29006
Some of my restorations
http://www.snapfish.com/snapfish/thu...NAME=snapfish/
Restored Tach tins 8 cyl - 6 cyl
http://67-72chevytrucks.com/vboard/s...d.php?t=518185
Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM
God Bless Our Troops
PT'S 70 CST is offline   Reply With Quote
Old 02-15-2011, 06:29 PM   #13
Lee H
Lee H's Avatar
Some hard core water stains are not something sitting on the glass. They are actually chemical etchings into the glass and hence almost impossible to get rid of. I had a 69 that I bought form a guy that let it sit under a sprinkler for a whole summer. I worked and worked and worked and finally took it to a glass guy for advidse. The side and back glass was so bad I had to replace it.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have all original numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 02-16-2011, 11:42 PM   #14
treveiger
treveiger's Avatar
I use a sharp razor blade, but you have to know what your doing or youll end up scratching it but it works awsome. I clean windows and glass as part of my job and i use razor blades on all of them.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 05-25-2011, 10:43 PM   #15
chevykid65
chevykid65's Avatar
the boss has me cleaning up his 64 f*rd falcon he picked up. he found it sitting in a barn where it was parked in the mid 80's. he had me do a quick cleanup with 0 steelwool and went back over it with 00. the glass was pretty gnarly when i started. it cleaned up really well. i wouldnt b afraid 2 use it on my 65 or my 62 olds.
chevykid65 is offline   Reply With Quote
Old 05-26-2011, 02:33 AM   #16
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
vingar and water with newspaper
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 08-17-2011, 11:17 AM   #17
big_al_71
big_al_71's Avatar
+1
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
