Closed Thread
Old 05-24-2011, 11:10 AM   #3076
joedoh
joedoh's Avatar
Re: What did you do to your truck today?
tagged it today, got a YOM plate from a friend. taxes and tags 77 dollars, 14 per year from now on.
joedoh is offline
Old 05-24-2011, 10:47 PM   #3077
willyp
willyp's Avatar
Originally Posted by 66farmer View Post
I like the grill, are you going to put it on your truck if so will it bolt up. What do you think it will cost to chrome it.
i think it will bolt up, i may have to drill a hole or two. called a couple places today about the chrome. no luck yet. also i still need one headlight bezel, the passenger side was rusted out. if its too much coin to chrome powder coating may be an option. thats what i did to my 66 grill.
The price of cool aint cheap.
willyp is offline
Old 05-24-2011, 11:04 PM   #3078
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Originally Posted by willyp View Post
i found this 60 grill on a chimney sweep truck in a junkyard near my house saturday.....i would like to chrome it
Twin lights. Very cool!
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline
Old 05-25-2011, 07:14 PM   #3079
1966JSM
picked up a used bed for the truck.
1966JSM is offline
Old 05-25-2011, 08:31 PM   #3080
T2vigil
T2vigil's Avatar
Installed the three point harness in my 64. I will feel much safer now.
T2vigil is offline
Old 05-25-2011, 09:08 PM   #3081
1966JSM
what kind of belts did you get?
1966JSM is offline
Old 05-26-2011, 05:27 AM   #3082
T2vigil
T2vigil's Avatar
I used the Juliano's three point retractable along with their attachment kit. It worked pretty good but the instructions were vague with very little details. The drivers side attached to the flat part of the floor on the drivers side. On the passengers side I had to "Open Up" the angle so it would fit the angle of the floor. This allowed the retractable end to mount vertically as it did on the driver"s side.
T2vigil is offline
Old 05-26-2011, 01:02 PM   #3083
jimmydean
jimmydean's Avatar
Got the face for my tach, it was a little big, but I was able to trim it. I think it turned out pretty good considering how little I've spent on these.
I have a few clocks in mind, might go looking this weekend. Would like to get this all done and back in the cab.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline
Old 05-26-2011, 01:10 PM   #3084
shortbed70
shortbed70's Avatar
Sanding body filler last night and I will do the same tonight. Hope to have the bed done in 2 weeks!
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline
Old 05-26-2011, 08:09 PM   #3085
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
I had rebuilt a small scooter with a BIG BORE kit and kept the old parts. I ran across the 50cc piston the other day and thought it would be cool as a suicide knob. The "tractor" knob was in two halfs. I removed the top and shaved down the bottom till it fit inside the piston. There is a small ridge inside the bottom of the piston. I used JB Quik to bond them together.
Here it is.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline
Old 05-26-2011, 08:59 PM   #3086
LeftCoast32
Custom Builder
LeftCoast32's Avatar
I picked up a few pieces that were done at Chrome Plating.
Gauge Cluster Surround
1966 Deluxe Wheel Horn
Sun Visor Brackets
LeftCoast32 is offline
Old 05-26-2011, 09:34 PM   #3087
66-PMD-GMC
66-PMD-GMC's Avatar
That gauge cluster looks great.
What gauges did you use?
I have a GMC and the cluser is different but I would switch it out if it looked as good as yours.
Projects..
440CID 2X4 Pontiac
Old 05-26-2011, 09:53 PM   #3088
LeftCoast32
Custom Builder
All are correct factory guages to include the Tach and refaced Vac gauge.
Old 05-26-2011, 10:05 PM   #3089
CdM
CdM's Avatar
Here it is.
That's RAD!!!!!!
painted some parts and cleared em.
Build Thread 66 custom cab lwb http://67-72chevytrucks.com/vboard/s...d.php?t=465726
66 fleet lwb- In process
64 k10 10inch lift 38.5's- In process
92k1500 400hp on 38.5-parts truck now 8(
CdM is offline
Old 05-26-2011, 11:47 PM   #3090
66-PMD-GMC
66-PMD-GMC's Avatar
Are re-pops sold and if so where? That is a beautiful instrument cluster.
PM me if telling me here is against the etiquette police's rules.
Projects..
440CID 2X4 Pontiac
Old 05-26-2011, 11:51 PM   #3091
LeftCoast32
Custom Builder
I purchased most everything off ebay. I used 3 different stock gauge clusters and rebuilt the best parts out of all of them.
The hard parts to find are the Tach, Tach Transmitter and Vac Gauges.
I have a ton of leftover parts that could be restored into everything except the Tach and Vac. Then when you find them you just bolt them right in.
Here are a few Gauge Clusters and a Vac Gauge on ebay now:
http://cgi.ebay.com/ebaymotors/1964-...item1c1c0d49c3
http://cgi.ebay.com/ebaymotors/64-65...item19c5c285df
http://cgi.ebay.com/ebaymotors/1964-...item19c5bbc912
http://cgi.ebay.com/ebaymotors/60-66...item2a10e20d22
Old 05-27-2011, 12:09 AM   #3092
66-PMD-GMC
66-PMD-GMC's Avatar
I was surfing through the 67-72 website here and found out the Chevy and GMC are not only a different layout, they are also different sizes. I'll have to find a different gage cluster panel and fix it up to hold the gages I want in it.
I am also converting my 63 Chevy to a GMC and that means I'll need to change the Chevy dash to GMC.
Not really a big deal as the Chevy dash is butchered beyond recognition but I'll need to make up my ever changing mind before I weld in a new dash....
Do I REALLY want to convert???
Projects..
440CID 2X4 Pontiac
Old 05-27-2011, 12:24 AM   #3093
LeftCoast32
Custom Builder
There is a Chevy Dash on ebay right now too.
http://cgi.ebay.com/ebaymotors/64-65...item2a10e5d4c3
Old 05-27-2011, 07:41 AM   #3094
csa daddy
csa daddy's Avatar
cut springs out of truck an set new bed on gots some cutting too do today an some welding
csa daddy is offline
Old 05-27-2011, 11:25 AM   #3095
DannyK
DannyK's Avatar
I'm swapping a few parts off an identical truck to mine I got for almost nothing in a trade and then I'll put it on CL for a nice profit ! haha, I like being unemployed, I make more money !
'94 Chevy K1500 Ext.Cab/Short Z-71 4x4 350 TBI/4L60E (my tow rig)....and assorted other vehicles.
DannyK is offline
Old 05-27-2011, 10:15 PM   #3096
monolith
Zero Albedo
monolith's Avatar
Picked up a Holmes 440 wrecker bed for my 3/4T
Gotta massage it a bit before it fits perfectly, and maybe see how I can shed some weight off of it.
Now I need a PTO, and Manuals.
Baz
"Deserve's got nothin' to do with it."
66 GMC 1500 wideside longbed 250 4spd "Project Rekker"http://67-72chevytrucks.com/vboard/s...d.php?t=467467
65 GMC 1Ton Panelhttp://67-72chevytrucks.com/vboard/s...32#post4794432
65 Chevy Panel (former U.S.Navy truck)
64 Chevy Suburban Carryall 4x4http://67-72chevytrucks.com/vboard/s...d.php?t=358348
64 GMC 1000 wideside longbed 305 4spdhttp://67-72chevytrucks.com/vboard/s....php?p=3600890(Rip- parts truck now)
68 Dodge Charger
monolith is offline
Old 05-27-2011, 10:31 PM   #3097
towersddg9
towersddg9's Avatar
Picked up my 12bolt from coater, blast and coat $120
towersddg9 is offline
Old 05-27-2011, 11:39 PM   #3098
raic65
raic65's Avatar
Installed 2001 Tahoe seats w/ power to take advantage of the 3-point belt. First picture were some cheapy seats I picked up a while ago because the factory bench seat broke. What a difference in comfort too.
raic65 is offline
Old 05-27-2011, 11:39 PM   #3099
Slow Build
Slow Build's Avatar
I was a tow truck driver for a short while around 1979 and I drove a 70 Chevy with the Holmes 440 on it. It never let me down (other than when I bent the front spoiler of a Cuda on a police impound call, oops).
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline
Old 05-27-2011, 11:51 PM   #3100
gmc1969
took mine out and did a dump run
gmc1969 is offline
Closed Thread
