#1376 | |
![]() Join Date: Feb 2011
Re: ** YOUNG FRANKENSTEIN ** The truck Chevrolet should have built.
Paul Posted via Mobile Device
1969 C/20, 307, 4-speed, rusty with manual steering and brakes! |
#1377 | |
VA72C10
![]() Join Date: Mar 2008
...but glad the truck will no longer be neglected ![]() ![]()
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#1378 |
Sorry guys. GO MAVS!!!
Rich 1970 C/10 Step, 383/700R4 http://67-72chevytrucks.com/vboard/s...d.php?t=466601 |
#1379 |
Any updates?
'72 Nova '71 C10 '63 VW Beetle ![]() ...............................____ .................________-|___\____ ..;.;;.:;:;.,;.|__(O)___|____/_(O)| _______________________________________ |
#1380 |
6>8 Plugless........
![]() Join Date: Sep 2007
Drew the truck is looking awesome! I had to go back several pages to pick up where I left off. Very nice work as always! I am really thinking about getting a burb lined up so I can build myself a hauler this winter. I want as much cab room as I can get. With that being said, seeing how you have done yours already. Do you think you could cut the burb body at the front of the rear wheel well and then add the truck cab rear portion on there?I'd like to have a lot of cab room if I can.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#1381 | |
Lucky Teter at the wheel
Drew YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!) The Bride is currently under the knife!
#1382 |
the ones that were done for special orders like the one they modified to build the truck in your profile pic Drew were tad bit longer. the rear doors were the front doors and were something like 4" or 6" longer. that's just a guess on the measurements but you all get the idea.
![]() ![]() ![]() 67 c10 swb build in progress 70 c10 lwb driver pending parts for drastic overhaul 70 c20 lwb parts truck for above mentioned drastic overhaul 71 k20 lwb building for off road use and towing Last edited by maynardtruckin; 05-24-2011 at 11:46 PM. |
#1383 | |
#1384 |
Ok, something worth posting finally. - Although I'm not quite sure-
Started in on my possible headliner that requires some creative fabrication. I used 3 layers of thin plastic to keep my roof and cab clean. Then I spread out the black fleece - I realize now I should have tried to stretch it tighter. I spread out the fiberglass resin on the fleece , but some areas cured quicker than others and it puckered up in one or two spots. Then I laid on my fiberglass resin again and spread out woven roving type fiberglass mat with more resin on top of that. It seems pretty stiff, I'll have to trim it around the edges and fit it in there. Then cover it with headliner material. Now that I have done this, I have a different idea so I may not end up with this at all. If I love it great, if not, plan B.
#1385 |
Nice work! I know that fiberglass work in big chunks like that can be a real joy!
#1386 |
67cheby
![]() Join Date: Sep 2008
WOW...thats alot of fiberglass !!
#1387 |
![]() Join Date: Jul 2010
Too bad you couldn't put the cab on one of those rotating devices, tipping it upside down, working it from the inside.
#1388 |
that was my thought too. that way it would fit the inside of the cab perfectly instead of the outside.
#1389 |
The way Drew is doing it is exactly how a lot of street rod guys do it. Once they get the shape they cut it, fit it, and then put it back together. Just think how nice it would be bending over, leaning in to do the fiberglass work because it isn't like you can sit on the inner roof panel to do it while it's upside down.
#1390 |
Yes, I am actually going to spray these 4 panels tomorrow. It's about dang time.
#1391 |
Looking good!
#1392 |
Great, I can't wait to see this project come together. It's gonna look awesome.
#1393 | |
looks great drew. can't wait to see some color! |
#1394 |
Well, I did get paint on them. That's about all I can say.
I'll probably end up respraying 3 of the 4 panels shown here. Bummer.
#1395 |
VA72C10
BUMMER....what's the issue?
#1396 | |
Drew, that stinks about the paint issue. Was it a reaction or something?
#1397 |
Been following the build and it's lookin awesome, it keeps me motivated to work on my on my work, keep up the good work and don't feel to bad about the paint, I'm about to repaint my truck for the 3rd time in 3 months.
Posted via Mobile Device |
#1398 |
Runs and trash in the paint. I could wet sand and buff, but each bad area is near a body line and I would probably burn through and have to repaint anyway.
#1399 |
it was just a couple of warm-up passes. now you're ready for game-speed painting.
#1400 |
I'm going to try and redo it tonight, wish me luck!
