Old 05-24-2011, 04:33 PM   #501
kart34
Re: Extreme Powder Coating '65 C-10 Shop Truck
This is the process for top-coating the C-10 frame...we sanded the frame down, and blew the dust off ... wipe down with wax and grease remover... tag rag off the dust and apply top-coat.
edited by staff
kart34 is offline   Reply With Quote
Old 05-24-2011, 04:44 PM   #502
kart34
The frame moved back into the paint booth where it got its final coat and headed into the curing oven...came out looking like glass. Tiger Drylac Ral.7042 gray 90 -95 percent gloss . You always get a good finish with Tiger products. We used about 4 lbs. of powder for the topcoat on the chassis and misc. parts.
edited by staff
Old 05-24-2011, 06:17 PM   #503
jimmydean
jimmydean's Avatar
Wow, that looks incredible. Nice work, now get that pig back together!
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 05-24-2011, 06:31 PM   #504
kart34
OK assembly starts Wed. AM Powdercoating inside of cab / roof /firewall soon .. maybe Friday.
edited by staff
Old 05-24-2011, 06:55 PM   #505
lolife99
67-72 parts collector,…
lolife99's Avatar
Quality work in those pics!
There are alot of powdercoaters should take a look at your process.
I wish you were closer to me,... so I could send you some business!
Keith
Convert to disc brakes.
Old 05-24-2011, 09:02 PM   #506
kart34
Lolife99, We are working on a small parts powdercoating program. You ship it too Extreme .... we pay the frt. back to you via US Post office.
edited by staff
Old 05-24-2011, 09:21 PM   #507
jimmydean
jimmydean's Avatar
I want to see a shot of Nate's bridge in that color in the sunshine. Damn that frame looks so good.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 05-24-2011, 09:47 PM   #508
kart34
Going to have a little pinstriping done asap on the Porterbuilt bridge. Looks like we will have the rolling chassis at "Back to the Fifties" June 17,18,19, on display in the Extreme Powder Coating booth.
edited by staff
Old 05-25-2011, 03:13 PM   #509
kart34
Rear End Housing and Pallet of parts for the C-10 coated!!
Organizing other parts for powdercoat! Cleaning up the C-10 shop today
edited by staff
Old 05-27-2011, 11:57 AM   #510
Delmo
Delmo's Avatar
Awesome as usual. I can't imagine the time you guys have into that beast.
Delmo is offline   Reply With Quote
Old 05-27-2011, 11:59 AM   #511
jimmydean
jimmydean's Avatar
This truck isn't back together yet? Man, I am dying to see this bridge with the pin stripes.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 05-27-2011, 01:15 PM   #512
kart34
Working on it this weekend... stay tuned in !!!!
edited by staff
Old 06-01-2011, 02:49 PM   #513
kart34
Got the cab back from the sandblaster.. GT Blast-Tech. We have to fix a few rust spots that appeared in the blasting process. We will shoot a red oxide epoxy powdercoat primer on it asap. Then fix the rust spots and starting working with the powdercoatable bondo product we will be testing. stay tuned.
edited by staff
Old 06-01-2011, 02:52 PM   #514
kart34
Jesse is getting it put back together... should have a rolling chassis this week. Relic Pinstriping is going to work his magic on Monday.
edited by staff
Old 06-02-2011, 01:23 PM   #515
kart34
The center council has a built in tray for the Garmin - Dynamat is in - fixed up the floor in the cab - this is our powdercoat bondo we will be using - and the frame and parts are coming together!
edited by staff
Old 06-02-2011, 01:27 PM   #516
kart34
more shots of putting the C-10 back together
edited by staff
Old 06-02-2011, 01:29 PM   #517
SCOTI
SCOTI's Avatar
What is your exhaust coating process? What type of material is used?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 06-02-2011, 01:38 PM   #518
jimmydean
jimmydean's Avatar
Man, that looks awesome. Love the exhaust, too.
Scoti, there is a powder I have used that looks exactly like that called "header coating" that cures at 400 and is supposed to be good to 1500 degrees or so once cured. I was going to use it on my street bike project until I round the titanium ceramic.
The ceramic coating worked better than the powder as far as engine performance, but did not hold up to daily driving like the powder does.
I hope to see that chassis in person some day, that powder looks incredible.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 06-02-2011, 02:51 PM   #519
pdxhall
pdxhall's Avatar
Hey Kart, been following your build for a while. The frame is looking great(and everything else). I just noticed that it looks like you might be using an early mustang or falcon gas tank. Is this true? If so I'm curious about what you did about the sending unit ohms or do you have a guage that matches? I'm seriously thinking with going with that tank on my 66 LWB with stock fuel guage and need to adapt to the stock fuel guage.
pdxhall is offline   Reply With Quote
Old 06-02-2011, 09:09 PM   #520
kart34
Scotti, The exhaust was custom built in house . I purchased some mandrel bends on e-bay and Jesse worked his magic. The coating process is burn off all oils ( bake in oven for a few hours or more) . Then we blast them with alum. oxide and apply the liquid ceramic . This is the same coating that we sprayed on the 2011 Ridler Award winner for Bruce Ricks.
edited by staff
Old 06-02-2011, 09:17 PM   #521
kart34
The gas tank is from Tanks Inc. and is for a 65 Mustang or Falcon ? We have not done any wiring yet but will be using Classic Intruments elec. gauges. Von Hot Rod white faced with blue pinstripng limited edition gauges so I hope we can get it wired up to work with the Mustang sending unit.
edited by staff
Old 06-03-2011, 12:05 AM   #522
pdxhall
pdxhall's Avatar
It should be easy if you can get a guage that is for the early mustang with the proper ohms. It not I found this link to a vendor that can modify or build a sender to work with your guages. You might check them out. I haven't contacted them yet because I'm not quite ready to install my tank.
http://tristarrradiator.com/Custom%2...ed%20Page.html
Old 06-03-2011, 01:02 AM   #523
Dinos63
chevy only
Dinos63's Avatar
wow thats a bingo!! killer job duudes great skills
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 06-03-2011, 01:04 PM   #524
jimmydean
jimmydean's Avatar
You used ceramic on the exhaust! Bravo, sir. This build is top shelf at every level.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 06-03-2011, 03:15 PM   #525
kieth
kieth's Avatar
Saw the picture of the garmin nuvi and thought I would give you a heads up, there is a nuvi 765t that can be purchased as a refurb unit for $133.00 on amazon.
I build motorcycle audio systems and this little power house has all the same features as the 900.00 brothers, a micro sd card slot, audio output, and mike out put, bluetooth for the phone......keep it in mind on your next build. Kieth
kieth is offline   Reply With Quote
'65, c-10, carter hickman designs, extreme powder coating
