05-26-2011, 11:35 PM | #1 |
Rookie new rear end new Drive shaft??
I have a few ? can ya help a brother out
1- I am swapping my 6 lug rear end to a 5 lug rear end off a 85 chevy truck am I going to need to swap out drive shafts or can the same one work I currently have a 2 piece shaft now or is it better to have a single shaft? 2-I am going to replace the rear coils with airbags I order a c notch from CPP on ebay can someone put up some pix of air bags mounted not sure if i need to remove the rivits where the coil was before thanks |
05-27-2011, 11:22 AM | #2 | |
Re: Rookie new rear end new Drive shaft??
Air bag install as posted in the FAQ/truck tech/suspenion section.... http://67-72chevytrucks.com/vboard/s...d.php?t=129463
05-27-2011, 01:52 PM | #3 |
thanks for the info
