Closed Thread
Old 05-28-2011, 01:33 AM   #3101
rafasbadhabit
rafasbadhabit's Avatar
Re: What did you do to your truck today?
added newer seats, by old bench was to torn up.
seats look good and felt really good, removed the headrest to look more like buddy seats.
rafasbadhabit is offline
Old 05-29-2011, 12:43 PM   #3102
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
The PO of my truck cut out the steel floor to install airbags and he never did. I took advantage for the last 9 months to install bags, comp, tank, shocks, trackbar, exhaust and other stuff. It was real nice to work on things with the floor missing. Now that all the hard stuff was done, it was time to put the floor back in. It was kinda hacked out of there so you will see missing pieces up front and one small part in the rear. I think that was to fix a bed mount. I added some braces up front to support the bed.
Here is a few pics of the floor install. I will finish more later. I plan to redo the rollon bedliner when all the metal is in.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline
Old 05-29-2011, 04:52 PM   #3103
jbgroby
jbgroby's Avatar
Oh Happy Day, I picked up the doors from the painters!!! As you can see Art does not believe in short cuts. He made sure the back side of the inner door panels were (although it does not matter to me if there black or silver) He also made sure to straighten out and clean the drain holes at the door bottoms and spray a nice layer of rubberized coating on the interior door bottoms.
jbgroby is offline
Old 05-29-2011, 04:56 PM   #3104
LeftCoast32
Custom Builder
LeftCoast32's Avatar
Very nice work on the doors!
LeftCoast32 is offline
Old 05-29-2011, 11:03 PM   #3105
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Oh so clean....
My dream doors for my 63 ...
I'm jealous..
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline
Old 05-30-2011, 03:14 PM   #3106
lakeroadster
Making some more progress on the doors. Installed window seals and finished painting door panels. Once I get some glass setting tape I can re-assemble the windows.
lakeroadster is offline
Old 05-30-2011, 04:12 PM   #3107
steverino66
Finally sprayed epoxy primer on the bed - spent way more time setting up than painting (first ever effort with the hvlp gun - too easy!)
Cutting/fitting white oak bed boards is next…
steverino66 is offline
Old 05-30-2011, 06:38 PM   #3108
LeftCoast32
Custom Builder
Good job! You did real nice for the first time with an HVLP gun!
Old 05-30-2011, 07:47 PM   #3109
steverino66
Thanks - just like the first welding effort, anticipation was much worse than just doing it. This was just the cheapo primer gun, the real challenge will be color, but that's down the road a bit.
Old 05-30-2011, 08:20 PM   #3110
old chevy truck
took off old mirrors and put on original ones and put bumper guards on and newer straighter grill and finished up on the fount sway bar brackets.
old chevy truck is offline
Old 05-30-2011, 09:22 PM   #3111
1966Stepside
1966Stepside's Avatar
Wrestled my 5.3/4l60E in place. Going to finish it up and take pics on Wednesday.
1966Stepside is offline
Old 05-30-2011, 11:55 PM   #3112
jimmydean
jimmydean's Avatar
Got my clock square and installed. I didn't like the face plate I made first, so I redid it and got the clock face centered in the hole. Looks good enough for me. Still need to do the bezel and maybe a new lens.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline
Old 05-31-2011, 12:03 AM   #3113
markeb01
Senior Enthusiast
markeb01's Avatar
I agree, very nice job. That came out great.
markeb01 is offline
Old 05-31-2011, 11:31 AM   #3114
Dan in Pasadena
Dan in Pasadena's Avatar
What is that clock out of? Same question on the tach. Both very nice looking; great job.
Dan in Pasadena is offline
Old 05-31-2011, 11:38 AM   #3115
jimmydean
jimmydean's Avatar
Thanks. The clock is from a 2001 Chrysler 300M, the tach was in the truck when I bought it, it's made by Orbit(?) and the white face gauge kit I bought came with the stock looking vinyl face. I did have to trim the face and make some mods to the tach to get it to fit, but I think it turned out ok.
So a stock gauge with half sweep tach + about $30 for the clock, paint, and white face gauge kit and done.
<edit> The clock was $2.88 at pick-n-pull during the half price weekend.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 05-31-2011, 11:59 AM   #3116
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Went to look at a 6.2 that some one took all apart Cut harness.. And heeds were Off uggg.. He still wanted 3500.00
1971 GMC SHORTY is offline
Old 05-31-2011, 12:09 PM   #3117
markeb01
Senior Enthusiast
markeb01's Avatar
Gave the truck a bath yesterday and reset the passenger door. Moved the lower hinge inboard a tad and now the door latches as easily as the driver side. Also rubbed out the rear bumper where I splashed gas on it from siphoning fuel for the lawn mower.
markeb01 is offline
Old 05-31-2011, 09:26 PM   #3118
AllenKarber
I actually drove my truck Saturday for the first time since July. The aluminum head I had welded up seems to be fine! No coolant leaks! I need to bleed the brakes because I have no pedal at all. I had to do some pumping to stop.
I was just going to go around the block,but I was so excited I ended up riding for about 30 minutes VERY cautiously.
AllenKarber is offline
Old 06-01-2011, 05:43 AM   #3119
T2vigil
T2vigil's Avatar
I put almost 600 miles on mine over the weekend. Also picked up a left rear fender from a guy in Columbus GA. Only problem is the shifter started acting up. Made the drive home interesting, shifting from first to third. Ive got to find a way to fix the three on the tree.
T2vigil is offline
Old 06-01-2011, 11:05 AM   #3120
66-PMD-GMC
66-PMD-GMC's Avatar
Too bad your not closer. I have a perfect column shift column.
Projects..
440CID 2X4 Pontiac
Old 06-01-2011, 11:34 AM   #3121
T2vigil
T2vigil's Avatar
Good close-up photos could help out if that is possible. BTW I worked at the Springerville Power Plant a couple of years ago and lived in Eager. Small World. Terry
T2vigil is offline
Old 06-01-2011, 05:18 PM   #3122
Malibob
Malibob's Avatar
Sold it!
This statement was made possible by a grant from this station and continued support from viewers like you.
Flickr
Malibob is offline
Old 06-01-2011, 05:41 PM   #3123
onequickchevy
onequickchevy's Avatar
Wow, seems to be a trend lately. Think i'll hang in a little while. What are your plans?
Slowly but surely getting it done.
onequickchevy is offline
Old 06-01-2011, 05:55 PM   #3124
pdxhall
pdxhall's Avatar
My wife got done with her garage sale over the weekend and after hauling 2 loads of stuff to Goodwill, I have my garage back. Pulled the truck back in and started clean up of the rear frame and suspension. Still can't work much outside, the rain seems to show up every time I try to start working. Good to be back out of the weather. Also, the 65 belair steering wheel I bought showed up in the mail and I cleaned it up. All the Chrome is almost perfect and the normal small cracks in the plastic should be an easy repair. I like it!!
pdxhall is offline
Old 06-02-2011, 12:27 AM   #3125
Chvyman1975
Chvyman1975's Avatar
Today I took her heart out to get it all cleaned up. I found a number stamped on it that says 76. Does that mean its a 1976 motor? Its hard for me to want to do anything with it. I have been debating on building a stroked 327.
Chvyman1975 is offline
Closed Thread
