Old 05-27-2011, 01:38 PM   #1401
RagingAsian
RagingAsian's Avatar
Re: ** YOUNG FRANKENSTEIN ** The truck Chevrolet should have built.
my goodness, I like this project, but I wont lie, I cringed a little when I found out what you did to the sub.
Susie-Honda Accord Coupe|Elisa-1968 Chevy C20
Holdin' it down in the 520
RagingAsian is offline   Reply With Quote
Old 05-27-2011, 09:21 PM   #1402
Newtz67
Newtz67's Avatar
I'm sure as soon as I post this someone will let me know why. Maybe I've been drinking too much, but why did you mask off the centers of the doors, but not the fenders?
Newtz67 is offline   Reply With Quote
Old 05-27-2011, 09:26 PM   #1403
67cheby
67cheby
67cheby's Avatar
i actually wondered the same thing
67cheby is offline   Reply With Quote
Old 05-27-2011, 09:33 PM   #1404
Newtz67
Newtz67's Avatar
Thank God, I thought I was a little slow or something haha.
Old 05-27-2011, 11:25 PM   #1405
bundeber
he was having problems aligning the molding on the fenders as there isn't a constant body line to make sure they were square to the world. I believe he knows where that line will be on the doors, and will hang the fenders to locate the white area on there later.
bundeber is offline   Reply With Quote
Old 05-27-2011, 11:31 PM   #1406
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
I went round and round on where the upper molding should go on the fenders. I know where in theory, but what if the front end of the molding needs to be adjusted a quarter or half inch up or down so that it runs straight with the rest of it on the doors and bed? You can't do it because the upper molding stops about 1 inch short and leaves your paint break line showing. On top of that the molding comes to a point and so it is critical that your paint line is exactly in the middle. I just had a bad feeling that on the final assembly my front upper molding might end up running uphill or down. I am going to mount and adjust all the sheet metal and then pull a string to mark where to mount the molding on the fender, drill the holes, tape/plastic the whole truck and shoot the white on just the fenders at the end. I might be over thinking it, but better safe than sorry.
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 05-27-2011, 11:32 PM   #1407
drewskiren
drewskiren's Avatar
Exactly, you just type faster than me.
Drew
Old 05-27-2011, 11:45 PM   #1408
drewskiren
drewskiren's Avatar
Liquid frustration.
A big fat run pictured, and 2 pics of a landfill worth of trash that took up residency in my fresh paint.
Last pic is a shot of wet sanded with 600 grit but I need to hit it with the block and sandpaper just a tad more to get rid of those few shiny spots of trash.
And if anyone is wondering, I have not re-primered, this what the blue looks like when wet sanded.
Drew
Old 05-28-2011, 01:35 AM   #1409
Newtz67
Newtz67's Avatar
Ok, I remember reading that now. That makes sense! So what changed from the time you painted the interior till now to affect the amount of trash? I ask because I'm becoming a huge fan of guys doing their own paint and want to learn all i can from others.
Old 05-28-2011, 09:20 AM   #1410
fencepost
fencepost's Avatar
Try misting the plastic walls and floor down with water prior to painting, also blow off parts before painting and wipe down with tack rag. You may have done these things just thought I would chime in.
fencepost is offline   Reply With Quote
Old 05-28-2011, 10:05 AM   #1411
classicchev
classicchev's Avatar
Drew, why did all the other parts that you painted look so nice, then the last batch turns out fuzzy? Seems like alot of crap, seems like whenever that happens to me its usually my gun that has not been cleaned properly, and the new solvents are "melting" the old in the gun and blowing the lovely little chunks.
Just a thought, and remember I bought my booth at the same place you got yours!!!!
Darren
67- 72 Parts collecter
classicchev is offline   Reply With Quote
Old 05-28-2011, 11:21 AM   #1412
68 TT
Still plays with trucks
68 TT's Avatar
Liquid frustration.
I've seen that before when a coworker that was just out in the work area sanding down a truck came into the paint booth to spray some parts. He was in a hurry and forgot to blow himself off before he came in. The sanding dust on his body & hair came off and ended up all over the paint. The booth was clean and sprayed down but he was not. Just a thought.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 05-28-2011, 11:43 PM   #1413
drewskiren
drewskiren's Avatar
Darren
Thanks for the tips, I think I had the fender sitting on a table that I did not clean. I should have blown it off, or covered it with plastic. I also didn't tack cloth off the paper on the doors. I blew off everything and the walls and floors last night and shot it again this morning and it turned out much better.
Drew
Old 05-29-2011, 01:03 PM   #1414
Newtz67
Newtz67's Avatar
Good deal!
Old 05-29-2011, 09:31 PM   #1415
drewskiren
drewskiren's Avatar
Here we go with some pics of the door and fender success.
Drew
Old 05-29-2011, 09:32 PM   #1416
VA72C10
VA72C10
VA72C10's Avatar
looking good!
Old 05-29-2011, 09:35 PM   #1417
my4by2
my4by2's Avatar
Much improved & very nice!
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 05-29-2011, 10:02 PM   #1418
LooseCannon
nice spray work
LooseCannon is offline   Reply With Quote
Old 05-29-2011, 11:07 PM   #1419
BlackTopMotors
Whatever you did this time it worked. Good Job/I'm taking notes.
BlackTopMotors is offline   Reply With Quote
Old 05-30-2011, 09:23 AM   #1420
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Nice and shiny ...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 05-30-2011, 09:38 AM   #1421
silverboy02
looking good man
silverboy02 is offline   Reply With Quote
Old 05-30-2011, 11:33 AM   #1422
Dandeluxe
Dandeluxe's Avatar
Smile Re: ** YOUNG FRANKENSTEIN ** The truck Chevrolet should have built.
Drew,
Wow!! very nice work .. NEVER to be a critic or knocking any of your work .but i was wondering why you did not locate the fuel tank filler in the rear opening of the left rear fender marker light .. Does any one know where the old link for this modification is on here ? a while back some guy on here used a filler pipe .. He put it in the rear side marker light area .. he used the filler door harware from a s-1o p/u donar i think for the hinge and door .. he was able to fill his gas tank from the rear side marker opening.. i want to do this on mine as well .. someday with a rear tank.. any way..
Your truck is awesome and you are an amazing mechanic and metal worker . a true crafsman. i cant wait to see this on the road..
GOD BLESS AND KEEP THOSE PIC.S COMING.. DANDELUXE
1969 cst swb 350/400 th . DANNY C .
["]FRIENDS DONT LET FRIENDS DRIVE F@RD$!!
1969 cst swb corvette hugger orange with 400 hp sbc
I started out with nothing and i held on to it
Dandeluxe is offline   Reply With Quote
Old 05-30-2011, 12:16 PM   #1423
drewskiren
drewskiren's Avatar
Originally Posted by Dandeluxe View Post
Drew,
My free gas tank, part of my free frame/engine/trans/rear axle /wiring /etc, has a filler neck that aims towards the front of the truck. I don't remember what page, but I have pictures of it on here. Since I am going for the stock sleeper look, I wouldn't want to shave the gas filler, and the gas tank neck lines up perfectly with it - so there you have it. I want the truck to look original so that the main thing that jumps out at you is " Wow, that sure is a clean factory crew cab". Not, "wow, that thing sure has a ton of body modifications done to it - look they even made it into a crew cab." See the difference?
Drew
Old 05-30-2011, 02:55 PM   #1424
butternut1972
butternut1972's Avatar
Paint looks nice.
1972 GMC (PROJECT LONG OVERDUE)
1998 SWB 4WD
butternut1972 is offline   Reply With Quote
Old 05-30-2011, 04:33 PM   #1425
jamie72
jamie72's Avatar
somehow didn`t see this build,from last night to now,i`m impressed.. i`d say this is one of the top 3 builds that made me say wow,since i`ve been on this site. great job can`t wait to see it completed..
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
