"GO DAWGS"
Wheel and tire size questions ?
I am going to be running 275/60/15's on the 8" rim which I have ran for years. My question is for the front, I want to run a 235/70/15 and was looking to buy a 6.5" van rally wheel and do not know if I would be better off with a 6.5" or 7" wheel. both tires are dead even in circumference at 87.8" on the front and 87.9" on the rear. So my question is should I go with the 6.5's or 7's on the front. http://www.miata.net/garage/tirecalc.html
Thanks PT ![]()
70 CST SWB 70 NOVA 93 Indy 500 Pace Truck (SOLD) 94 SILVERADO SWB 5/7 drop 2000 Silverado swb 2005 Nissan Altima 3.5 (Surprisingly very fast) 2004 GMC Yukon XL Denali BATESBURG, SC. 29006 29006 Some of my restorations http://www.snapfish.com/snapfish/thu...NAME=snapfish/ Restored Tach tins 8 cyl - 6 cyl http://67-72chevytrucks.com/vboard/s...d.php?t=518185 Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM God Bless Our Troops |
Roadtrip!
![]() Join Date: Feb 2003
Re: Wheel and tire size questions ?
Personally i would go wider on the front. I like a little "dish" to the wheels. This is the same set up as you are mentioning except with an 8" up front.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
"GO DAWGS"
Eric the only problem with the 8's up front are that is what I am running now and this set up is on my 94 silverado with a 4/6 drop and I am running 15x8" Weld Draglite XP's and they are rubbing the outer lip up front. I am going to run rally's for awhile and wanted to get something to tuck up front and I think the 6.5 or 7" rally's will work. The problem is that I have dozens of 8" rally's but need to buy the 6.5's or 7's. I have found some 6.5's from a board member and am sure the 7's will even be an easier find I just did not know if the 6.5" with that 235/60/15 would be to much side wall bulging out of the side.
PT
"GO DAWGS"
ttt
It's alsways something.....
![]() Join Date: Nov 2008
8" Rallys were too wide to tuck after my suspension drop (2 1/2" spindles and 1 coil off springs) I went to pull-a-part and bought these 2 off a 87 or so chevy van for like $5.00 each (inc the junk P235/70R15 tires that are on them in this pic)
I changed to TTO 15x7 with P225/70 now (in sec photo) hope this helps! Chuck
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
"GO DAWGS"
Hey thanks man and that is one nice looking truck.
PT
Personally, i dont think the .5" difference will matter. Either wheel would work fine, but I think a 225/70/15 tire would make it look more proportioned
