#26 |
Grandpa in the rustmobile...
Re: Whats the procedure for cutting front springs..
Cool keep us updated! Is he gonna try to run a trac bar or make one?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#27 |
Chevy Lover Till The End.
I'm not sure. I was suppose to go up and visit him today in my '69 but it's raining. I may drive something else and head up anyway. I will let you know. Ted
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011 1989 Chevy Silverado, 4X4 - Daily Driver 1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck 1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original. Members I've met: BamaBaxter, My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359 |
#28 |
Instead of cutting one coil from the bottom, would it be better to cut half a coil from the top and half a coil from the bottom?
![]() ![]() It ain't yours, if you didn't build it! |
#29 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
The bottom (only) can be cut. The top has a smaller pigtail end that fits up in the crossmember, and matches up to a "D" shaped piece of steel. When you have the spring out,... look up in the spring pocket and you will see it.
#30 |
I chopped the coils on my impala and iwas told to put the cut ends up top.Big mistake!One side worked its way up into a little opening in the frame and that side wouldnt move.I had to take it apart took me about two days to pull that spring out of there.
#31 |
Happy to be here
![]() Join Date: Mar 2000
Just an FYI for anyone considering cutting a coil spring. There are several ways to cut them, and as mentioned always avoid excessive heat. I have used many of the methods mentioned. One that wasn't mentioned is a "tile" blade in a circular saw. A tile blade is essentially a thin abrasive disc like those used in a cut-off tool. This is larger and made with the correct style arbor so it fits properly in a circular saw. If you don't have anything else to do the job, that old Black and Decker or Skill saw will work just fine.
#32 |
It's alsways something.....
![]() Join Date: Nov 2008
I used a cut-off wheel in my 4 1/2" side grinder to cut mine. (brand name--METABO 'original slicer' is the deal!) Here is a photo for reference, it has 1/2 coil removed and 2 1/2" drop spindle. 5" drop springs on the rear.
I did this suspension mod during the build and then it went to the alignment shop, had it aligned, all was good... ![]()
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e Last edited by chuckmc8; 05-27-2011 at 10:53 AM. |
#33 | |
![]() Join Date: Feb 2001
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#34 |
#35 | |
Tags |
goose is loose |
