Old 05-30-2011, 12:04 AM   #16
Captainfab
60-66 Nut
Re: Vortec heads on 3892657 small block 327?
For a good cam, I would suggest looking at the Comp Cams Extreme 4x4 cams. Give comp's tech line a call and tell them what you have and how you intend to use it. Be prepared to give then all the pertainent info on your truck. In addition to the engine specs, transmission type, rear end gear ratio, and tire size in diameter.
Originally Posted by Spassmacher View Post
I'm not sure yet. Once you go beyond bolt-on components, I get a little lost. What would be the best fit for this type of setup? I want to get what I can out of it without losing any reliability. It's still going to be used as a truck, and I don't have the money or the need to turn this engine into anything drastic.
1967, 327, 3892657, heads, vortec
