Rear disc brake???? blackbird, wilwood, brackets
Question.... Who knows if the blackbird kit for "71-87 5-lug" will work with the wilwood D52 calipers and the stock rotors from the front wheels.
I see where Captainfab has made a bracket for the D52s but it says, "These brackets will bolt onto the truck 12 bolt rear differentials from '64-'82 and the 10 bolt truck differentials from '83-'87." So what brakets out there work with the 12 bolt 5 lug for an 83-87 with the D52 calipers or Wilwood D52 calipers? It doesnt really matter to me what kinda rotors they are. Can some of you guys post up what your rear disc conversion combo consists of. Thanks a bunch
1983 Chevy C10 lwb 305 1984 Chevy C10 swb (planning an LSx swap) 2005 Ford Crown Vic A4 (patrol car) SOLD...1998 Camaro Z28 SOLD...2005 GTO |
#2 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Rear disc brake???? blackbird, wilwood, brackets
I thought they were all 10-bolts by then.
I believe that's correct. 12-bolts through 80-81; 10-bolts after.
Slots go on anything!
Yep. No 12 bolts after '81. I don't think any rear disc brake kit will work with a front rotor from our trucks. The design of the rotor is completely different; they are made to ride on a spindle, vs sitting on an axle flange.
1974 Jimmy- 5.3/4L80e/NP241 |
Ok thanks guys,
after I posted this someone did tell me about the 12 bolt not going past 81'. But thanks for the replies and information.
| Bookmarks |
| Tags |
| blackbird, bracket, brakes, d52, wilwood |
