Old 05-29-2011, 11:32 PM   #1
Mikewb
cutting springs
after you cut a coil off of your springs do you just have to get a normal allignment or something that costs more?
Mikewb is offline   Reply With Quote
Old 05-29-2011, 11:34 PM   #2
85_C10_Sleeper
85_C10_Sleeper's Avatar
Re: cutting springs
plan on having ALOT of shims if you dont have longer upper control arms...
But no just take it to an alignment shop and theyll do it. I do my own alignments, much funner that way and you can learn alot.
85 C10 LWB
305ci - 700r4 - 10 bolt - 3:08 gears
Collecting parts for a 'mild prerunner"
85_C10_Sleeper is offline   Reply With Quote
Old 05-29-2011, 11:45 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: cutting springs
The plain old alignment will do just fine.,
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-29-2011, 11:46 PM   #4
Mikewb
Re: cutting springs
just want to cut one coil. is it safe to have that many shims?
Old 05-29-2011, 11:53 PM   #5
Mikewb
Re: cutting springs
ok thanks bro
Old 05-30-2011, 12:16 AM   #6
SCOTI
SCOTI's Avatar
Re: cutting springs
While an alignment is an alignment, some techs simply do not like working on modified/lowered vehicles & price the work accordingly. Try & find a shop that has a guy that's into 'classics' & you should be ok.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-30-2011, 12:22 AM   #7
Mikewb
Re: cutting springs
ok. how hard is it to allign yourself? you would only have to add shims on the upper control arm right?
Old 05-30-2011, 09:56 AM   #8
kev2809
low n' slo
kev2809's Avatar
Re: cutting springs
for camber...but if your wheels or turned in or out then its a little more work.
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 05-30-2011, 10:05 AM   #9
LONGHAIR
Re: cutting springs
It takes special tools (gauges) to do this. It can be done "at home" if you have the proper equipment.....it is NOT an "eye-ball" thing.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 05-30-2011, 11:59 PM   #10
85_C10_Sleeper
Re: cutting springs
Its not an eyeball thing if you scribe the tires and do it that way... The way they do it on top fuel cars, Sprint cars, and the way they did it before about 15 years ago... I do mine at home because i have a Camber & Caster guage. And honestly. 90% of the time if you take it to a normal shop theyll do a terrible job because they dont know ANYTHING about suspension geometry and only know what the computer tells them to do.
But hey, to each its own.
85 C10 LWB
Old 05-31-2011, 12:03 AM   #11
Mikewb
Re: cutting springs
Yea i agree ive had em done and truck pulled all over the road
Old 05-31-2011, 12:49 AM   #12
85_C10_Sleeper
Re: cutting springs
id pickup a camber caster guage... theyre 100-200 bucks, but its worth it.
85 C10 LWB
Old 05-31-2011, 10:14 AM   #13
Shane
Shane's Avatar
Re: cutting springs
don't believe everything you read online. take it to someone with the right equipment.
Shane is offline   Reply With Quote
Old 05-31-2011, 11:06 AM   #14
Tony@AirRideTech
Junior Member
Re: cutting springs
Tony@AirRideTech is offline   Reply With Quote
Old 05-31-2011, 06:58 PM   #15
LONGHAIR
Re: cutting springs
You are obviouly acquainted with some very lousy shops....But, they are NOT affecting the actual geometry of the system by doing an alignment
Scribe the tires?
Alignment on a TF car is a very different thing....They have a TON of positive caster, for hi-speed stability. That's why they "flop" so badly at extreme turns.
Sprint cars...another bad example. They "steer" off of the rear tires (stagger) and the fronts are actually steering "into the turn" IE turned right while going left....
Bottom line, with-out a caster camber guage the only thing you can do is guess and "eyeball"....not good, it will eat your tires.
Just have it done by a quality shop with a warranty on the workmanship.
Old 05-31-2011, 09:44 PM   #16
leddzepp
Moderator
leddzepp's Avatar
Re: cutting springs
I chopped a full coil off of each of my springs, for a 2-2.5" drop. The alignment shop only had to add one additional shim to each stud on either side upper control arm.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-31-2011, 11:19 PM   #17
85_C10_Sleeper
Re: cutting springs
I have a camber caster guage... i dont know if i said that allready. Good investment.
85 C10 LWB
Old 05-31-2011, 11:34 PM   #18
leddzepp
Moderator
leddzepp's Avatar
Re: cutting springs
The best place to go here in town is Jerl's Muffler on Indiana. There is a dude there named Scotty that has been doing alignments for over 30 years. He dialed my truck in perfectly.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
