Closed Thread
Old 05-28-2011, 01:10 AM   #2301
ItsRandy
ItsRandy's Avatar
Re: What did you do to your truck today!
Over the last few days, I installed a new quick ratio steering box, new power steering pump and a set of March pulleys, oh, and a Zoops power steering pump bracket.
ItsRandy is offline
Old 05-28-2011, 03:19 AM   #2302
RossRinSD
RossRinSD's Avatar
I haven't got much work done on the K10, sorry guys. I got busy with a transmission swap in my Monte Carlo. Hope to get the SS all sanded down and primed this weekend, then back to the Blazer gas tank install
RossRinSD is offline
Old 05-28-2011, 12:45 PM   #2303
71Longbed
Not Mine But A beauty
71Longbed's Avatar
i havent done anything in over a year
68 Chevy Shortbed 454/400
2000 Chevrolet Camaro SS 6spd
2011 Silverado 5.3 6spd auto
71Longbed is offline
Old 05-28-2011, 01:16 PM   #2304
kcsa75
kcsa75's Avatar
Loaded a winter's worth of dead tree limbs, then proceeded to get stuck in the mud!
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline
Old 05-28-2011, 04:38 PM   #2305
wtchop
wtchop's Avatar
replaced the driver's side window regulator.
wtchop is offline
Old 05-28-2011, 05:38 PM   #2306
fast50ranger
fast50ranger's Avatar
Replaced my hood hinges..No more headaches for me
Big Block Powered
fast50ranger is offline
Old 05-29-2011, 12:46 AM   #2307
ItsRandy
ItsRandy's Avatar
Finally took the cab ALL the way off of my frame so I can start the body work. Got all of my pulleys shimmed and lined up. Stuffed my dip stick and tube in my transmission. Fell off a ladder. Cleaned up my garage.
ItsRandy is offline
Old 05-29-2011, 02:10 AM   #2308
rondog4416
rondog4416's Avatar
drove it for the first time !!!! what a thrill !!!
rondog4416 is offline
Old 05-29-2011, 11:02 AM   #2309
Bennett68C10
Bennett68C10's Avatar
Finished grinding smooth all the welds on my exhaust and then laid down my first coat of por-20 silver exhaust paint. Has to dry for 24hrs before second coat can go on.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline
Old 05-29-2011, 12:45 PM   #2310
frednoah
86 Scottsdale
Got after it pretty good this weekend.Friday I put in the battery tray I bought from the board to replace what was left of my old one.
Then, this morning, I went inside the cab, and laid on my head and surgically repaired shoulder for an hour and a half changing out the damn stoplight switch. My hands just couldn't get up there to loosen the top nut to drop it out. Turns out my trucks PO had crossthreaded it.
After about an hour of messing with it, I grabbed a pair of dikes and proceeded to cut at the old plastic until I could pull the bottom nut off. Once it was off I pushed the stump up through the hole and out.
In the end I won. My brake lights now only come on if you're actually pushing on the pedal ().
To treat myself after all that hard work, I took the 2 minutes to install the new park light lenses in the grill.
frednoah is offline
Old 05-29-2011, 06:20 PM   #2311
profe56
I changed the high prressure power stering pump hose
Uploaded with ImageShack.us
profe56 is offline
Old 05-29-2011, 09:02 PM   #2312
stomper
Junior Member
stomper's Avatar
Talking Re: What did you do to your truck today!
Mounted the uhaul hitch on my 72 K5
"I was patina when patina wasn't cool."
1973 Cheyenne SWB Sunset Gold / Frost White / Saddle
stomper is offline
Old 05-30-2011, 10:08 AM   #2313
72chevy383
got around to putting my Slotted/drilled rotors on, calipers, shocks and brake hose to the frame. Here's some pics.
Today I'll be putting on the front tie rods, pitman arm, idler arm etc.
72chevy383 is offline
Old 05-30-2011, 07:37 PM   #2314
67c10rustbuket
67c10rustbuket's Avatar
Took my bed off with an engine hoist by myself, cut off the cab corner and trimmed the floor so i can install the new floor edge once i blast and strip everything that didnt rust itself to death. rust sucks
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline
Old 05-30-2011, 08:02 PM   #2315
mdaven@aol.com
Replaced the turn signal due to adding a tilt steering column. Signals work, horn works, making progress slowly.
mdaven@aol.com is offline
Old 05-30-2011, 09:54 PM   #2316
Dismounted all the tires from the 70 and put them on my 83 (and vice-versa). Then I cleaned and rearranged the shop so I could fit & sorta work on both trucks. It's still crowded when the 83 is in there, but at least I can open both doors on the 83 and walk around the truck to do stuff.
Palf70Step is offline
Old 05-30-2011, 10:05 PM   #2317
fast50ranger
Mounted and wired my electric fans. I really hate wiring!!!
Big Block Powered
Old 05-30-2011, 11:44 PM   #2318
5557ID
Worked on my Vintage Air installation......
I cut the hole for the center vent and assembled & installed the condenser/drier.
68 C10 - LWB, 327/TH400 (original 307)
75 Buick Century - Stage 1 455
5557ID is offline
Old 05-31-2011, 01:23 AM   #2319
ItsRandy
ItsRandy's Avatar
What year truck are you puttin' that Vintage Air in? How do you like it? Small or Big Block motor? Does everything fit as they say it will? Sorry for all of the questions.
ItsRandy is offline
Old 05-31-2011, 03:43 AM   #2320
69C-owner
I bought an intake :-), carb, intake gaskets, radiator, hoses, and a thermostat oh and a good battery are all next on the list of "gettin her goin" parts, gotta do title work somewhere in the middle of that mess
http://67-72chevytrucks.com/vboard/s...d.php?t=43855069 LWB Fleet
1994 Buick Roadmaster
1994 GMC Sonoma
69C-owner is offline
Old 05-31-2011, 09:52 AM   #2321
5557ID
No problem......It's a 68 w/ a 327. I'm only just getting started with the install, but so far things are going together quite well. I did have to enlarge the mounting holes on the top bracket for the condenser. You can sort of see that in the pics.
This is their latest offering for our trucks which is servo controlled. Will be interested to see how it works.
5557ID is offline
Old 05-31-2011, 10:29 AM   #2322
custom1970
Member
custom1970's Avatar
Made some under seat speaker boxes and installed some 6" x 9" speakers. Finished installing new radio and putting dash back together.
1970 CST LB Fleetside, 402 BB, PS, PB,AC
1968 Firebird 400 conv.
1965 Chris Craft 17' wood ski boat (SN #0001)
custom1970 is offline
Old 05-31-2011, 10:38 AM   #2323
treeboy97
treeboy97's Avatar
yesterday..
replaced a throwout bearing and put in my rebuilt manual steering box.
1970 C10 LWB (Grandfather's Truck) 5.3 4L60E
2012 Victory Cross Country Touring
I'm not wasting money on my truck/bike, I'm helping to rescue the economy one mod at a time.
treeboy97 is offline
Old 05-31-2011, 01:56 PM   #2324
mleeb
mleeb's Avatar
The long memorial weekend was productive...I swapped out my alternator to a 1-wire, byrassed ext. regulator. I also prepped and painted my new to me edelbrock intake, installed it and a new 1411 carb.
71 Chevy C-20 Fleetside
Stock 402 BB-Summit Headers-700R4 Trans
Dual 40 series flowmaster w/ H pipe
Edelbrock 2161 intake & 1411 Carb
mleeb is offline
Old 05-31-2011, 08:23 PM   #2325
Jeffs70
Jeffs70's Avatar
Well I Finely Broke down and had to Sale my Truck.
LOL Yeah right to that. I have to much invested into this one to sale lol. any how I did good yesturday Finely Sold the Donor I got the Bed and Frame and some other parts off of. and the good news is I fixed it back up decent enough to sale for just around the same price I purchased it for and saved a donor instead of trashing it. so I think I gained in this project just under 3k so now the good thing will be that money will go directly into this project to get it on the road this summer i hope..yay I am stoked!
Jeffs70 is offline
Closed Thread
