Grandpa in the rustmobile...
Re: "Rice Rocket'
I have a 71 MC (2nd or 3rd one now), less than 6 months old. I have a new brass disc drum prop valve also. New soft lines calipers etc etc
I'll messs with it sometime this week. Thanks for the imput keep it comming. Will try cracking a bleeer and see what happens. I can loosen the bearing up a little too.....
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Re: "Rice Rocket'
keep workin on it and you will get it buddy!
Junk Yartist
Re: "Rice Rocket'
K. I just saw your video of your wheel. It does kinda look like your wheel bearings are too tight, not your brakes dragging. But if you are still skeptical about your brakes dragging, maybe you have a warped rotor? Even new ones are not perfect (I have a set on my Yukon now I just want to chuck at someone!) take some spray paint and put a light guide coat on the rotors and spin them. See if it wears off evenly.
definitely redo your wheel bearing torque. See if your wheel seal is leaking. Use synthetic grease.
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
