Old 05-27-2010, 09:02 PM   #51
1949gmc
Re: Headers to 2.5" Ramhorns
This needs to be brought back to the top again for everyone.
The manifolds from Speedway Motors are the Dorman manifolds, just so everyone knows.
1949gmc is offline   Reply With Quote
Old 05-27-2010, 09:19 PM   #52
bigeasycigars
bigeasycigars's Avatar
Awesome!! Thanks!!
bigeasycigars is offline   Reply With Quote
Old 05-27-2010, 09:21 PM   #53
1949gmc
Originally Posted by bigeasycigars View Post
Awesome!! Thanks!!
You got it, man! Thought you might find this helpful!
Old 05-28-2010, 09:24 AM   #54
TonyJohnson
TonyJohnson's Avatar
Currently I have stock ram horns with custom 2 1/4" to magnaflows and then dumping behind the rear wheels. I picked up a set of the Dorman 204s, ground them down and they're ready to go on, but I need to mate them to my 2 1/4.
Speedway recommends using header collectors for mounting the exhaust to these. Anyone here use them? Any other ideas? I thought about just using some stiff wire and making a template for 2 1/2" head pipes and then using a slip fitting on the other end to clamp over the 2 1/4... What did you guys do? Would I lose much staying with the 2 1/4 after the magnaflows?
Tony Johnson
-- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer --
TonyJohnson is offline   Reply With Quote
Old 05-28-2010, 10:26 AM   #55
jaros44sr
jaros44sr's Avatar
Looks like they are 60 bucks ea. in my new speedway catalog. Thanks for bringing an ol' post BTTT '49gmc
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is online now   Reply With Quote
Old 12-03-2010, 11:44 PM   #56
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
My 65 that I'm still looking for had classic corvette 2.5 RamHorns.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 12-04-2010, 05:10 AM   #57
AlaskaMatt
AlaskaMatt's Avatar
Bookmark.
Funny I was reading this same thread a week or two ago after searching for header options. Good info here.
Thanks,
Matt
My Website
AlaskaMatt is offline   Reply With Quote
Old 01-28-2011, 11:25 PM   #58
LostMy65
LostMy65's Avatar
So is everyone happy with the Dorman's?
Are you getting the DOR-674-504 or DOR-674-503?
These are the 2-1/2" correct.
Old 01-29-2011, 01:44 AM   #59
LostMy65
LostMy65's Avatar
RockAuto has them for $47.79 for either the DOR-674-504 or DOR-674-503.
They add $8 each for shipping.
Amazon has the 504s for 55.94 with free shipping.
but if you got two rights from amazon, you could have two 503s to your doorstep for $98.40
Old 01-29-2011, 02:08 AM   #60
LostMy65
LostMy65's Avatar
Ok, I found the answer:
Originally Posted by smbrouss70 View Post
Mine came in yesterday! Dorman 674504 is what you want, if you don't want the heat tubes.
Also this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=404828
The left (Driver's side) doesn't have the 'heat tube'
Old 03-09-2011, 01:43 AM   #61
mcmlxix
Collector of Projects
mcmlxix's Avatar
another alternative....
http://www.jegs.com/i/Wysco/938/MA035RAW/10002/-1
Rich
1972 K5 Blazer CST Click HERE
Old 03-09-2011, 06:24 AM   #62
72freak
Rottenwood Garage Member
72freak's Avatar
I just did a set on my 69. Engine in stock V8 possition. They really look nice. I got the ones with no brackets or heat tube holes. I also did extensive research to find a set of plug wires that were long enough to wire it correctly from the bottom without having to buy 2 sets or make them. It turned out nice. Ill take a picture to day of the completed engine bay.
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 03-09-2011, 10:24 AM   #63
TonyJohnson
Where'd you get those collector tubes? Are they just standard header type?
Tony Johnson
Old 03-09-2011, 10:38 AM   #64
Effeckt
Effeckt's Avatar
Originally Posted by mcmlxix View Post
Still available on amazon for $55 each shipped currently also.
My 1972 K5 Blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=399719
Effeckt is offline   Reply With Quote
Old 03-09-2011, 02:44 PM   #65
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Details please on your exhaust pipes!
Any clearance issues to the starter (and is it the stock full size starter)?
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 03-09-2011, 08:42 PM   #66
72freak
72freak's Avatar
Normal 2.5 straight runs just like any other dual exhaust with 40 series. No issues. The common myth that there are clearance issues with x-members with the engine in the v-8 position or clearance issues with stock starters is just that...a myth!. I have noticed I will probably need to make a shield for where the exhaust pipe comes close to the front right brake line where it wraps around the frame...its a little close.
Yes...collectors welded on to pre bent 2.5 pipe. I told/showed my muffler guy what I wanted and he made them for me. I had 2 sets made exactly the same for the next project.
Old 03-09-2011, 09:23 PM   #67
TonyJohnson
Cool...
Tony Johnson
Old 03-10-2011, 12:36 AM   #68
rsavage
rsavage's Avatar
Nice "unmod". I'm a firm believer in stock exhaust manifolds for a variety of reasons looks, ease of plug access, less heat in the truck, easier on the starter, etc. With the center dump ram horns, the wires were designed to run underneath along the block and up to the plugs with 90 degree angle boots. Cylinders 1,3 and 2,4 actually come up through in-between the block and motor mount. Run like that with the stock heat shields, they shouldn't burn. One other note, if you are keeping your truck stock, I don't believe that the heat stove sheet metal will fit over the 2 1/2 " exhaust manifolds - you would have to stick with the 2".
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 03-10-2011, 11:47 AM   #69
Effeckt
Effeckt's Avatar
So reading through this thread, I began wondering if you all would recommend getting the 2.5 ram horns over the factory ram horns? I recently found the factory 2" ram horns that already dump out at an angle in my garage. The PO put headers on my Blazer but I have an exhaust leak so I'm wanting to redo the whole system now. Would the extra .5" be worth while getting the Corvette horns or should I stick with the ones I've got?
My 1972 K5 Blazer
Old 03-10-2011, 12:26 PM   #70
rsavage
rsavage's Avatar
They are 25% larger so they will flow better. Probably wouldn't notice on a stock engine. Your Blazer is a 4WD. 4WD used the straight down center dump whereas 2WD uses the angled. I am not sure whether or not you would run into clearance issues with the angled dumps because I have never tried it. Perhaps someone else can tell you.
1961 C1 Corvette
2021 Durango RT 5.7
Old 03-10-2011, 02:06 PM   #71
drunkbus
New Member
drunkbus's Avatar
It was a tight fit to the starter on mine but there is room to make it happen. I ran heat wrap for the first few feet on both sides since it is so close to the starter and transmission cooler lines and the oil filter on the other side.
drunkbus is offline   Reply With Quote
Old 05-31-2011, 09:34 PM   #72
Cap'n Hook
Workin to live...
Cap'n Hook's Avatar
Does anyone know if the Dorman 674-504 lefts will fit Vortec heads? I've got a nice big hole started on the #2 cylinder and I'm tired of the leaking flanges!
Jason
Cap'n Hook is offline   Reply With Quote
Old 06-01-2011, 08:31 AM   #73
MrGoodpliers
MrGoodpliers's Avatar
Welcome home.
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC...
MrGoodpliers is offline   Reply With Quote
Old 06-01-2011, 01:24 PM   #74
jaros44sr
jaros44sr's Avatar
Yep, got them on mine! If it has the molded in boss, you can cut it off with an angle grinder and a cutoff wheel.
Thing is, if you run the heat sheilds, you might have a problem with mounting them up. The Vortec heads are about 1/2" taller
Main question is...do you run gaskets or not...big debate floating around the boards. I don't, I am just using copper shield. Also, I think the factory locking plates will work best to mount your manifolds, no more loose bolts that create leaks
Don't forget you need a new intake, although they make a dual pattern bolt, for the early intakes, the runners are about 3/8" short for the earlier intakes
SAFETY FIRST
AS usual, off topic
Jim
Old 06-01-2011, 09:47 PM   #75
Mike C
Mike C's Avatar
It is a 25% larger diameter, but that is not what makes the difference.
If the exit is the largest restriction, the 2" manifolds have a 1 x 1 x pi=3.14 sq inch opening. The 2 1/2" manifolds have a 1.25 x 1.25 x pi=4.9 sq inch opening. That is a 4.9/3.14=1.6 times as much so a 60% increase in area which should have a huge impact on the ability to flow.
My opinion is just about any performance level can benefit with the 'vette manifolds.
On my truck the "butt-o-meter" said they made more low speed torque than the headers they replaced with no loss on the top end. But it has a little cam, 210 @ .050. This is not a fair apples and apples comparison because the headers had 2 1/4" exhaust with some Turbo King mufflers while the manifolds got 2 1/2" pipe with Dynomax Hemi turbos.
Regardless, one of the best mods ever IMO. Good power with low noise and no maintenance.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Mike C is online now   Reply With Quote
