Closed Thread
Old 06-01-2011, 07:51 AM   #1
Low & Slow
Re: What did you do to your truck today!
I took a shot in the face bleeding the master cylinder. Apparently there was an air bubble in the line
Low & Slow is offline
Old 06-01-2011, 09:15 AM   #2
60ratrod
yes, i do
60ratrod's Avatar
sounds like me when i primed the oil system in my 60 because i forgot to install the mechanical oil pressure gauge line. i never want to know what mobil1 tastes like ever again
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline
Old 06-01-2011, 04:06 PM   #3
caboutin
caboutin's Avatar
replaced diverter box in air con/heat system and cleaned all other duct work. my "S" duct is damaged so I gotta order another. I adjusted all the cables to ensure full movement and eyeballed every aspect of the system. I rubbed some "bay rum oil" from Plum Island Soap Company in the duct work to condition it and give it a little odor. :}
added a chrome water pump from Jegs and had the lower bolt hole of my a/c bracket welded back together. U never know what u r gonna find when u start digging in these old rods.
I added a spring to my passenger side kick panel door vent that will close the door when I switch back to the "outside" air mode. took me forever to figure out how to get that damn door to close on it own.
gave the carpet a hair cut where the mats have opened some of the loops.
Washed and detailed the engine and suspension. Washed the body also.
Installed 2 new parking lamp assemblies in the front bumper.
changed the oil and filter.
busy boy!!!
caboutin is offline
Old 06-04-2011, 08:24 AM   #4
into69z
"brand new second-hand"
into69z's Avatar
busy boy!!!
What did you use/do to trim the carpet? I have the same problem and want to fix it.......
Steve
69 3/4t custom camper
tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c
67 Camaro
96 Impala ss-sold
04 hybrid Honda-saving gas for the blue truck!:
b69:
into69z is offline
Old 06-04-2011, 04:50 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Unloaded the freshly sandblasted/painted brake drums, 1-inch stabilizer bar, upper and lower control arms and transmission crossmember from my '96. Mocked up the transmission crossmember, then posed a question on here about correct placement.
Life is good.
Member Nr. 2770
ChevLoRay is offline
Old 06-04-2011, 01:56 AM   #6
hotrodhomi
hotrodhomi's Avatar
I hope you had your safety glasses on .
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline
Closed Thread
