Old 07-11-2001, 11:30 AM   #1
johnymac
Question Not happy with a 3/5 drop, any suggestions ?
I have a 67 C10. I replaced the springs and shocks with drop springs and drop shocks.
I chose a 3/5 drop cause the sales people said with a 6 inch drop in the rear I would have to notch the frame. I got several replies from people out here that had a 6" rear drop and were fine. I should of went with the 6" drop in the rear.
My question is, if I go with lowering blocks, I have rear coils, will it warp the axles, or give me wheel hop. I was reading that lowering blocks were not a good choice for lowering.
I would like to lower the back about another inch a half. Without cutting the new spring, or replacing the lowered shock.
Any suggestions?
Thank you.
johnymac is offline   Reply With Quote
Old 07-11-2001, 01:23 PM   #2
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
Post
nothing wrong with blocks as long as you don't go bigger than 2in. Whoever said that must have been smokin somthing, or they installed them wrong which is not the blocks fault just the BLOCKHEAD.
68chevy with93stepside on bags tuckin 17's 97 Honda 900 RR 6 color change chameleon paint polished frame and wheels
95 Tahoe dropped 4in on 18in Niche's.
01 Tahoe 22's 2/4 drop and tv's
68 chevy money pit
51 chevy belair
95 Honda 900RR
05 GMC Siearra (company truck)
NSANE68!!! is offline   Reply With Quote
Old 07-13-2001, 11:09 AM   #3
Z16
Post
Lowering blocks work great, but as a suggestion, I would have some built that are angled. As you have already dropped a long way with coils, The pinion angle of the rear axle is way out of wack compared to the output of the transmission (or steady bearing). You may get a vibration, or wheelhop, or it just may wear out U joints quicker. What you want is a block that when installed returns the pinion angle to close to stock. Try one of the suppliers that advertise in these pages. Also, you may need an adjustable track bar to re-center the rear end under the truck.
98 GMC Sierra Ex Cab, cowl hood, Euro LED lights, 30 bar billet, Whipple Supercharged 350 Vortec: Forged flattops, E-Tec aluminum heads, Comp Cam, Scat crank and rods, Granatelli Mass air flow, Headers, Flowmaster exhaust , Complete MSD Ignition, Custom Tuning, intake spacer , ported throttle body, AC Delco port injection upgrade, Roller Rockers, Power Pulleys. Gear Vendors Overdrive. Soon to hit a dyno. 2/4 drop(for now).
95 Chevy S-10 Ex Cab 4.3 5 Speed 2/3 drop, Euro lights, billet grill, More to come. The Daily Driver
Z16 is offline   Reply With Quote
Old 07-22-2001, 07:24 PM   #4
70 Jimmy
aka Crusher, Crushergmc
70 Jimmy's Avatar
Post
Yep, wooden blocks will give you wheel hop! LOL. The angle suggestion is right on.
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"It's funny till someone gets hurt, then it's freakin' hilarious"
70 Jimmy is offline   Reply With Quote
Old 05-31-2011, 05:30 PM   #5
OJ1988
Just a car guy
OJ1988's Avatar
Re: Not happy with a 3/5 drop, any suggestions ?
Are you going to take tbd front lower?
I installed 3/5 springs, and my front looks a little higher, maybe 1/4".
I was thinking about adding drop spindles to the front to get the rake back.
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 05-31-2011, 05:31 PM   #6
OJ1988
Just a car guy
OJ1988's Avatar
Pick of mine,
1973 Vega Drag Car
1970 C20 tow rig
Old 05-31-2011, 09:07 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
You can go with 1.5" blocks if you are running 15" wheels. Larger wheels will allow for a 2" block with out scrubline concerns.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-31-2011, 10:37 PM   #8
19seventeeCustom
^^here
I would just add a simple 1-1.5" block to your setup, a very inexpensive and worthwhile lowering method for these trucks in the rear. The nice thing about it is, if you have anykind of fab skills you can modify the block to the "exact" drop you need/desire.
19seventeeCustom is offline   Reply With Quote
Old 06-01-2011, 12:23 AM   #9
SCOTI
SCOTI's Avatar
I do believe this is the dustiest thread I've ever witnessed on this site. Almost 10yrs....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 06-01-2011, 12:46 AM   #10
jimmydean
jimmydean's Avatar
I wonder if he got blocks.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 06-01-2011, 07:19 AM   #11
OJ1988
Just a car guy
OJ1988's Avatar
Well, you know what everyone says, "search before you post"
so I searched
1973 Vega Drag Car
1970 C20 tow rig
Old 06-01-2011, 08:51 AM   #12
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by OJ1988 View Post
Well, you know what everyone says, "search before you post" ...so I searched
Yes you did, and thanks for doing it.
Now on to your question. I prefer to get as much drop from spindles as possible. A 3" spindle may require some mods to the A-arm, but it doesn't affect the ride quality. If you want more then trim the stock spring till your happy.
Articles-
"Refining Sierra"
Old 06-01-2011, 09:09 AM   #13
SCOTI
SCOTI's Avatar
so I searched
Not criticizing; just commenting on the gap between the last post & yours. I've seen some that were 3yrs, maybe even 5-6yrs..... never anything longer.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-01-2011, 10:14 AM   #14
Tony@AirRideTech
Junior Member
I think its awesome he was taking the time to search and educate himself on the subject first.... two thumbs up!
Tony@AirRideTech is offline   Reply With Quote
Old 06-01-2011, 10:18 AM   #15
SCOTI
SCOTI's Avatar
Agreed.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-01-2011, 12:22 PM   #16
entourageguy
Yellow truck club
entourageguy's Avatar
back shelf find behind the preserves......
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
