Not a bad nut after all..
Re: Help.. gearing stupidity
It may be cheaper for you to find a different set of axles and swap them in. If you are looking for another 12-bolt rear axle you are limited to '69-'72 4x4 to get the correct spring perches and shock mounts. For the front axle you can use any '71-'76 GM truck Dana 44; a '77-'91 corporate 10 bolt front axle could also be used with a driveshaft length modification.
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
| Bookmarks |
| Tags |
| axles, blazer, gearing, ratio |
