Shockwave 7000's on rear of my C20??
Hey Y'all! Not been here much in a long while. Just got laid off after 2.5 yrs and have some time to do some stuff.
I came across a new set of AirRide Tech Shockwave 7000. Never installed with dump valves, fitting and lines but no compressor, switches or gauge. Before I spend the pennies I'd like some input from you guys if possible. I know they will fit, but do you think these will hold up to the weight of my big rig? Thanks for the input Y'ALL!!
..............................._________ ......___________//___[[___{\ _____ ...../__(_(O)_)___/____/____/_(O)_/ 1964 C20 Long Stepside 3 Door Crew Cab - Armbruster-Stageway Conversion Y2K INDN Chief "ONE OF A KIND, NOT ONE OF THE CROWD" Aug 2010 - Front end frame cleanup & engine swap done!!! June 2011 - Rear end bagged Sept 2011 - Rebuild motor top end Sept 2012 - Parked and slowly working on it. Aug 2013 - Front end bagged - finally! Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas... Here is my build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=335427 Last edited by 64c20crewcab; 06-02-2011 at 06:15 PM. |
Re: Shockwave 7000's on rear of my C20??
If they are 8" indiameter and have 9-12" of height they should work just fine......Kieth
These are the 4" diameter for tight fit locations. No larger than the Monroe airshocks I have right now. But for the price I can get these for - it's very a good deal and a better ride (adjustable) than now with the 5" drop springs. Just need to grab the compressor at the Pomona swapmeet this weekend. Thanks
..............................._________ ......___________//___[[___{\ _____ ...../__(_(O)_)___/____/____/_(O)_/ 1964 C20 Long Stepside 3 Door Crew Cab - Armbruster-Stageway Conversion Y2K INDN Chief "ONE OF A KIND, NOT ONE OF THE CROWD" Aug 2010 - Front end frame cleanup & engine swap done!!! June 2011 - Rear end bagged Sept 2011 - Rebuild motor top end Sept 2012 - Parked and slowly working on it. Aug 2013 - Front end bagged - finally! Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas... Here is my build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=335427 |
The ride will not be good.......you will just be able to adjust ride height. If your truck is on coil spring you could but bags for about 60.00 each plus a set of brackets for 40.00, you could air them up with a remote compressor and have a plush ride and later add the compressor. Kieth
It's Better With Nitro
I think you may find that your rig is a little too heavy for these. IIRC, the capacity is around 1500 lbs (for the two - ~750 lbs each) at the max PSI.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
Thanks Guys! the price is very CHEAP no where is 900 retail price. May pick them up and turn them around at Pomona this weekend.
Kieth/All, What bags and brackets are you referring to? Suggestions please. I load up 700+lbs V-Twin motorcycles in it from time to time. Thanks!
What truck are you installing these on??
My 64 C20 Crew Cab. Before I posted I thought rig would be too heavy..
leaving the coils on? you will be fine how mmuch did you get them for?
I was gonna take them out. $100 bucks for all items I listed.
May hold off and just find brackets n bags this weekend at Pomona. If I did run the shockwaves n springs - these would do much better than the air shocks - correct? Thanks!
when you compress the shock does it stay down or come back up on its own?
Not tried it yet. Should they?
no if you compress them they should stay down. If they come up on there own they have become air charged and I would sell them
My buddy has them right now. I'll ask him to try this. He did mention that did have have them fully extended manually and then compressed. but was not able to extend again.
#15 |
quality Air Ride------------------for the basics you cannot beat it.
http://*******************/catalog/-6...ze-chevy-parts |
#16 |
thanks Keith. Was looking for bolt on brackets for the rear. Don't see them there but will ask them. I did just find this a few moments ago:
http://www.rollpans.com/product.asp?...ks&idno=263933
#17 |
if you are looking for a basic rear kit I can take care of you just let me know what you are trying to accomplish.
#18 |
Jon, Ok kewl! Recently laid off and want to do some budget minded but good work on the back end now and maybe front next month.
I have 5" CCP springs and air shocks in it now. C-notch from Brothers is on the work bench and planned to cut this in tomorrow. Basic needed for the rear for a bolt in bracket setup. Need bags lines, fittings etc... Thanks Also don't want to cut into bed just yet as I'm raising floor on both my fleet and step side beds for this truck. I just need to determine out how much to raise the floors....
..............................._________ ......___________//___[[___{\ _____ ...../__(_(O)_)___/____/____/_(O)_/ 1964 C20 Long Stepside 3 Door Crew Cab - Armbruster-Stageway Conversion Y2K INDN Chief "ONE OF A KIND, NOT ONE OF THE CROWD" Aug 2010 - Front end frame cleanup & engine swap done!!! June 2011 - Rear end bagged Sept 2011 - Rebuild motor top end Sept 2012 - Parked and slowly working on it. Aug 2013 - Front end bagged - finally! Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas... Here is my build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=335427 Last edited by 64c20crewcab; 06-03-2011 at 03:00 PM. Reason: added last line.... |
