05-24-2011, 09:55 AM | #1 |
What is the easiest way to remove woodgrain tailband tape.
I've made the decision to re-do my own woodgrain tailgate band. I've ordered the woodgrain tape from Cheyenne Super-Man. I will hopefully re-use my own metal letters. My question is what would be the best way to remove the old woodgrain tape. Is their a chemical that penetrates the 38 yr old tape and dissolves it enough to be removed with scrapping and scratching the original surface. I have a another band that's in bad shape that I can practice on. Any help or suggestions from those who have done this is appreciated. Thanks
05-24-2011, 10:11 AM | #2 |
SWB 4x4 Collector
Re: What is the easiest way to remove woodgrain tailband tape.
try spraying some penetrating oil and a razor blade, or 3m makes a woodgrain removal spray. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
05-24-2011, 10:44 AM | #3 |
I wonder if regular gel type paint remover would work. Out to the garage I go.
05-24-2011, 11:13 AM | #4 |
Man of Mini-Talents
Give Goof-off a try. Available nearly everywhere.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
05-24-2011, 11:35 AM | #5 |
I dealt with tons of woodgrain in the 70's-80's... start with a heat gun. Don't get it too hot, work a little at a time and pull it off. It works.
Then use tar and bug remover for the adhesive. Not fun but really it's the fastest and easiest way. Good luck!
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131 |
05-24-2011, 11:51 AM | #6 |
Active Member
For removing the adhesive residue, I've found that most products like "goof-off" work well, but only work for a short period of time. You spray it on, then wipe off the adhesive before it gets sticky again. If you let it sit the remover seems to evaporate and the adhesive gets sticky again. I've found it best to spray a little area, get it all clean, then move to then next spot. Sparying it all at once thinking it will saturate the adhesive turns out to be a waste of money. It's not something to let set overnight, or even a couple of minutes. Something like WD-40 might work that way though.
1957 GMC Ambulance 1962 Belair Wagon 1963 C80 Truck Cab *FOR SALE* 1969 Chevy C10 Short Bed 1972 Chevy C10 Long Bed *SOLD* 1996 C3500 Dually *SOLD* Last edited by 7T2; 05-24-2011 at 11:52 AM. |
05-24-2011, 12:40 PM | #7 |
05-24-2011, 01:48 PM | #8 |
I would stay away from real harsh chemicals. I am not positive but I think the aluminum is coated or anodized like the grill.
72 Cheyenne Super 80 Silverado Blazer 2wd |
05-24-2011, 02:06 PM | #9 |
Ive been removing 20 year old decals and you name it for years. The only and best way to remove without damaging under surface with not that much effort is to use a eraser wheel. Put it on a drill and go to town. It takes a little time depending on how big of area your doing but very good results.I get mine at Napa auto parts.Ill try and find a part #.
05-24-2011, 03:30 PM | #10 |
the boat guy
termites!
05-24-2011, 06:23 PM | #11 | |
05-24-2011, 07:35 PM | #12 |
the heat gun does very well on the tape.I used a couple cotton ball and lacquer thinner to clean of most of the glue.I even removed the black paint the same way.I polished and cleaned the trim first .Then repainted the black and added the wood grain.
05-24-2011, 10:07 PM | #13 |
Heat gun seems to work well on old decals
05-25-2011, 12:29 AM | #14 |
A guy with a truck
Just did this today on a couple of pieces of trim. Leave 'em out in the sun for a while, and the woodgrain will peel off in one piece, leaving very little residue. What is left is eaten away easily by acetone. I found this out after scraping and goof-offing another piece. Waaaay easier to let it get hot first...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
06-02-2011, 11:30 PM | #15 |
VA72C10
Anyone have a secret to putting the woodgrain back on with the letters on
I really don't want to take them off
Looking for a 67-72 swb or blazer project in or around VA. |
06-03-2011, 11:28 AM | #16 |
Hi Jonathan,
That would be a quite the feat and I would like to see a step by step photo of that process. I'm glad I kept my original band and replaced the woodgrain tape, because it came out better than I expected. I now have a whole set of new unused letters and clips to sell since I re-used my own metal letters The old tape came off in one easy piece using a blow dryer and patience. |
06-03-2011, 02:54 PM | #17 | |
VA72C10
So did you drill out the backs and then epoxy to re-attach the letters? Any advice is appreciated. I already have the new tape to use and a matching set for lower moldings so I can put together a super nice set.
06-03-2011, 02:55 PM | #18 |
i just used a razor blade and laquer thinner on mine
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
06-03-2011, 04:19 PM | #19 | |
Still Learning
06-03-2011, 06:11 PM | #20 | |
The difference for me was my letters has the GM part numbers cast in them and I had no reason not to re-use them. I was anticipating having to drill out the posts on my band so that's why I bought the replacement letters before removing my band, otherwise I would have noticed how they were attached and would not have bought the ones I did. Sorry my story can't help you. |
06-03-2011, 06:41 PM | #21 | |
Letters are metal with round circular push on clips for attachment to the band. GMCPauls part number is 381656, I paid $59.95 plus tax and shipping = $82.25. I'm gonna call and see if I can return them, don't know if there is a restocking fee or not either. The letters are individually in their own plastic sealed bags and the clips in another then everything in another plastic sealed bag. I opened the outer bag to compare the letters to mine. Depending on what I learn will determine which way I go. Have a great day. |
