Old 07-27-2003, 04:54 PM   #1
brad20653
Be careful out there
Just a reminder to be careful i just god scared to death i was ajusting carb when i dropped the screwdriver hit the fan clocked me in the head and stuck in my hood. I just couldnt believe it i thought i cracked my head open then thoughts of it sticking in my eye im still shaking so be careful out there
brad20653 is offline   Reply With Quote
Old 07-27-2003, 04:59 PM   #2
Pelon916
I am always worried about stuff like that when the engine is running.
I have a flex fan and the stories about fan blades breaking off and cutting up hoods always flash through my head when I'm under there.
Glad you're not hurt!
Pelon916 is offline   Reply With Quote
Old 07-27-2003, 05:00 PM   #3
brad20653
thanks i was gonna get a flex fan but dont have to hear stories a friend of mine had it happen lucky he was driving not under the hood
Old 07-27-2003, 11:44 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
It'll really scare the pee out of you if you reach in and your finger gets smacked by the fan.
Happened to me 3 times now, and I have been lucky so far, every time I have been hit on the finger nail and not flesh.
Old 07-28-2003, 01:15 AM   #5
Blue_71
Bloo
Blue_71's Avatar
ive had that happen once with the fan, i think it got me on the knuckle though.. somehow it didnt cut me, the ford was just warning me not to touch it i guess
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 07-28-2003, 03:05 AM   #6
devinfife
ive been hit on the finger by a fan and it wasnt bad at all
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
69 c-10. turquoise. 350 motor with 400 trans. long fleet. headers and dual flowmaster exhaust. K & N air cleaner, aluminum wheels and radials, stereo system and a bed liner. Manual drums and manual steering.
Kickin it in Seattle, WA
p.s. i love my longbed. must be a phallic thing.
devinfife is offline   Reply With Quote
Old 07-28-2003, 09:07 AM   #7
Z-72
I was doing the same thing, fine tuning the idle mixture when I fumble fingerd the screwdriver and it got in the fan and took out the radiator. That bent screwdriver is hanging on my tool box just for a reminder.
72-C-10-LWB-Big Block-TH400- PosiTrac Leaf Springs- A Dark Green Ford Eaten Machine. And those are not rust holes, there cooling vents..
Z-72 is offline   Reply With Quote
Old 07-28-2003, 11:51 AM   #8
jewels.
jewels.'s Avatar
yeah - i've gotten my finger in the fan before, and it smarts, but it never broke the skin.
wow - that whole screwdriver thing has me rethinking things! whew - you are lucky! thanks for the tip!
jewels.
68 C10 Red Step 350 my first child & main focus
58 3200 Apache LWB Step the upcoming project
jewels. is offline   Reply With Quote
Old 07-29-2003, 08:57 PM   #9
theo goebel
Yeah me too: While rowing thru the gears on my muncie with a hurst lock out, I heard a piece of tin hit the ground. I pulled over and popped the hood and found one of the fan blades had sheared off and took out the top of my shroud and there it was sitting on the intake manifold, I have not driven it since and the next time I do it will be to go to an auto parts store for a new fan and glue to fix the shroud!!!!thank god it hit the shroud and did not go through the hood.........
StepSideRideRequired
theo goebel is offline   Reply With Quote
Old 07-29-2003, 11:52 PM   #10
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
I hear you Longhormail! I wasn't thinking and dipped my hand down while i was reaching back from tuning my carb. I didn't want to look down, I thought I cut the tip of my finger off it hurt so bad. It turned out I had a little gash above my fingernail. I'm usually lucky with stuff like that.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 07-29-2003, 11:55 PM   #11
Southpa
Southpa's Avatar
There are accidents like dropping a tool in the wrong place while the engine is running. And then there is downright stupidity. I remember a deckhand working on a fishing boat wanted to check the tension on the alternator belt...while the engine was running. It ran his fingers right thru the pulley and messed him up.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 07-30-2003, 01:50 AM   #12
Hooter
My other Love
Hooter's Avatar
well i was trying to turn over my motor with a socket (engine off) when the socket slipped off and my thumb got sliced right open by the flex fan, those things friggen sharp!! man did it bleed, should of gotten stiched but being the Macgiver that I am I just stuck super glue in there and kept working.
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 07-30-2003, 10:23 AM   #13
palallin
That's what Super Glue was invented for. . . .
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 07-30-2003, 11:31 AM   #14
VTKidder
Call me a puss puss, but I refuse to come in from the front of the truck when it's running. Currently there's no shroud as I'm still balls-deep in the paint / assembly portion of the project, but if it's running, you can bet your sweet a$$ I'm coming in from the side to do something.
VTKidder is offline   Reply With Quote
Old 07-30-2003, 12:25 PM   #15
67chevemall
67chevemall's Avatar
Don't get a Flex Fan!!!!!!!!!!!!!!!
Keep Org. or get electric!
Save your arms teeth and Hood!
67chevemall is offline   Reply With Quote
Old 07-30-2003, 12:45 PM   #16
tyger25
tyger25's Avatar
I have the dual electric fan, but that wasn't what got me.....It was the belt! I was tuning the carb, and was more worried about the fan when my arm grazed the belt. Kinda like road rash, but only a half inch wide!
U.S.A.F.
68' C-10 Stepside
305 w/ 4 speed
tyger25 is offline   Reply With Quote
Old 07-30-2003, 12:49 PM   #17
jewels.
jewels.'s Avatar
Originally posted by VTKidder
Call me a puss puss, but I refuse to come in from the front of the truck when it's running. ... you can bet your sweet a$$ I'm coming in from the side to do something.
so are all of the previous posts/injuries occurring when ppl are working on the truck from the front when it is running?
i'm pretty short (5'5"), so i cant reach much from the front --- so i always come at things from the side - esp when she is running -- but even then, i still manage to act like a clutz and get my finger in the fan!
interesting....
jewels.
Old 07-30-2003, 01:14 PM   #18
landon4421
Life is Good !
landon4421's Avatar
did the same thing like a year ago. I was tightening up the radiator hose and lost the screw driver, and my fanschourd, and the screw driver stuck in the radiator. Bad day
'72 Chevy C10 4x4 shortbed "Project"
'71 Chevy C10 2wd longbed "partsrunner"
'91 Chevy Burb 4x4 "kidrunner"
'14 Honda Accord Sport "commuter"
landon4421 is offline   Reply With Quote
Old 07-30-2003, 01:20 PM   #19
GreenMystChevy
Thanks for the reminder.
I have a constant reminder because when I was 15 I found out that a metal fan connected to a running big block is just a bit stronger than my fingers. After a trip to the emergency room and a few too many stitches, these phantom pains are still around, something about cutting off nerve endings, whatever that means
Jeremy
'71 C-10
'72 GMC K2500
'72 Nova (Dad's)
'70 Chevelle SS
'55 Sedan Delivery
Attempting to build up this here 4x4...make her real tall and purty...well, maybe just tall
GreenMystChevy is offline   Reply With Quote
Old 07-30-2003, 01:44 PM   #20
VTKidder
Being 6'1" it's easy to reach the carb and what not from the front. The problem with that is when you're leaning in that far, the parts of you exposed to the fan are your neck and chest. I'm good with having no screwdrivers sticking out of my neck.:p
Old 07-30-2003, 02:34 PM   #21
69GMC396
I hear you guys. I'm 6' 4" so I can lean in no problem but when you lean in with a sweat shirt and the strings start hitting the fan that scares ya. I also know a guy that was working on a bulldozer from underneath (running) and shoved his hand in the fan. Cut it off. Ouch!
69GMC396 is offline   Reply With Quote
Old 07-30-2003, 03:03 PM   #22
Blue_71
Bloo
Blue_71's Avatar
jewels, i know what its like having to come in from the side to work... (see pic, im only 5'7") but the time i got my finger in the fan i was coming from the front, only time its happened so i'd have to say yup to your question
Old 07-30-2003, 03:22 PM   #23
Baradium
Binder Rep
Baradium's Avatar
Nice looking truck there!
The reason you can get lucky sometimes is the direction of rotation.. since you come in from behind the fan it pushes your finger out of the way with the slant... if you got in front of it it'd pull your finger in/ chop it off. You have to stick your finger in a lot farther from behind to get the sharp edge instead of slant, and it moves so fast it's hard to get it in that far before it gets pushed out... fortunately....
When I set the timing on the IH, I'm always paranoid about the belts and all being so close to my hands... that's one time when I'm glad the dizzy is in the back on the chevy... well I guess it's the only time, but anyways...
Baradium is offline   Reply With Quote
Old 07-30-2003, 03:43 PM   #24
jewels.
jewels.'s Avatar
oh thats so obvious! i should have noticed that! i'm a mechanical engineer! duh! thanks for pointin that out. no wonder i still have all ten fingers!
Blue_71 - i really like that picture of your truck! looks sweet! did you ever notice in that picture that your baseball cap matches the color of the truck, and your blue jeans match the color of the bowtie emblem on the truck? you and the truck match! you are made for each other!
ciao!
jewels.
Old 07-30-2003, 03:50 PM   #25
Baradium
Binder Rep
Baradium's Avatar
ciao!
jewels.
Sorry, can't tell if you are trying to be sarcastic or not... enough people said they didn't understand that I thought they might like to know...
