Old 06-04-2011, 01:05 AM   #1
j1970GMC
Crooked Steering Wheel Now Straight???
Hi Guys,
When I bought my truck I noticed that the steering wheel was not straight when the wheels were centered (pointing forward).
I'm not sure if I'm imagining this, but it seems to be straighter now than it was. It's got me worried that something is slipping within the steering box or steering linkage??
Anyone ever had this problem? I want to make sure it's safe to drive.
j1970GMC is offline   Reply With Quote
Old 06-04-2011, 01:14 AM   #2
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Re: Crooked Steering Wheel Now Straight???
Did you happen to move your head upright? lol
Sorry....just trying to be funny!
prostreetC-10 is offline   Reply With Quote
Old 06-04-2011, 05:34 AM   #3
JimKshortstep4x4
Check the mounting bolts on the steering box.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 06-04-2011, 10:29 AM   #4
68gmsee
Active Member
68gmsee's Avatar
I'd have a front end alignment done just to make sure. Also check the air on the front tires to make sure they're the same.
Another thing may be tire wear. Could be possible you have a tire that has a slipped belt and it may be pulling slightly to one side. Maybe swap with rear tires to see if it goes back to the way it was.
If all of that checks out... You're in luck! Got a self healing truck.
68gmsee is offline   Reply With Quote
Old 06-04-2011, 12:56 PM   #5
j1970GMC
Thank you for the replies! I'll check the mounting bolts and the tires and alignment. I don't want to worry about nothing but I want to be safe.
Thanks again.
