Old 06-03-2011, 10:29 PM   #1
cjlinkster
cjlinkster's Avatar
Front bed cap replacement
I've got a 1984 long bed, and its front bed cap (is that the correct term?) has been pushed forward toward the cab. From the LMC diagram, it appears that this front just bolts onto the rest of the bed???
How hard is it to change the front of the bed out? Would I have to remove the entire bed or could I just jack it up a few inches to get to the lower bolts?
Thanks,
John
cjlinkster is offline   Reply With Quote
Old 06-03-2011, 10:43 PM   #2
bigblock73
yeller
bigblock73's Avatar
Re: Front bed cap replacement
You'll need to remove most the bed side bolts as well (the ones going to the floor), in order to slide them out of the way enough to get the front panel out and new one back in.
bigblock73 is offline   Reply With Quote
Old 06-05-2011, 02:54 PM   #3
cjlinkster
cjlinkster's Avatar
So, the bed will not have to be totally removed from the truck? Thanks for your help.
Did you have to do this same replacement to your truck?
Old 06-05-2011, 02:58 PM   #4
kwin
kwin's Avatar
I just removed the bed sides from my 87 you should be able to access all bolts with out removing the bed. Wether or not you can remove and replace the head panel I have no idea.
There is one way to find out for sure....
Good luck
kwin is offline   Reply With Quote
Old 06-06-2011, 09:26 PM   #5
SeanPaintsFlames
SeanPaintsFlames's Avatar
Check Mar-K. They have free shipping and freight every once in a while. Shipping for those isn't cheap because they are big and much heavier than you'd think. They stepside front bed panel I got for mine was around $115 or so shipped from them.
http://www.mar-k.com/
And yes, it is just a handful of bolts. If you don't have a 1/2" Gearwrench, go ahead and get one now.
My 68 cougar restomod build:HERE
SeanPaintsFlames is offline   Reply With Quote
