Old 06-06-2011, 10:11 PM   #1
67_C-30
I have a radical idea!
67_C-30's Avatar
Saw a DMax Burb at the track today!
We went to Montgomery Motorsports Park to catch the Hot Rod Power Tour and I saw it making passes. It was ungodly hot and the track was slick as an onion, but the big Burb still ran a best time of 13.10 @ 108 while I was watching. It embarrassed several muscle cars and Cummins Dodge 2500. I wish I had been able to get some up close pics aand specifics, but the only place I ever saw it was running. The place was packed, and I don't know where he was parking...
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 06-06-2011, 10:36 PM   #2
vectorit
What?
vectorit's Avatar
Re: Saw a DMax Burb at the tarck today!
Awesome! To bad you couldn't get closer to check it out and talk to the owner.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 06-06-2011, 10:37 PM   #3
Monty
i like how it's in stealth trim.
Monty is offline   Reply With Quote
Old 06-07-2011, 10:52 PM   #4
capev86
Re: Saw a DMax Burb at the track today!
I could probably do a 15 sec 1/4 mile or better in my 72 burb c20 if i put my 406sbc and 700r4 in it. that 3 on the tree is fun but is not very quick.
if you ever see that truck again, you need to get the owner on this board!
capev86 is offline   Reply With Quote
Old 06-11-2011, 03:06 PM   #5
67_C-30
67_C-30's Avatar
No doubt. That's the bad thing, I never caught up with him. I just saw the Burb running. I would have looked to seen under the hood.
My trucks
Old 06-12-2011, 11:30 PM   #6
Infanti
www.infantimachine.com
Infanti's Avatar
I think this is the same suburban.I saw these pictures on the main message forum under 2011 Hot Rod power tour.
Infanti is offline   Reply With Quote
Old 06-13-2011, 05:42 PM   #7
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Very cool setup!
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 06-16-2011, 10:42 PM   #8
67_C-30
67_C-30's Avatar
Yes! That is it. Thanks for posting the pics. I was really wanting to see under hood!
My trucks
Old 06-17-2011, 10:35 AM   #9
Bryanl
Does anyone have anymore info. on this build? I'm curious about the transmission setup and how they got it to ride so low.
That is an awesome ride. I have a 72 Sub and an 04 Sub Dmax conversion but the ultimate for me will be to put the 72 body on the late model chassis. I'm thinking the way to do it is swap the dmax into a suburban chassis like mine. The wheelbase between the 72 and 04 is pretty close. So I'm thinking that with a small body lift it could be close enough that you wouldn't have to cut up the frame. But I am just speculating.
Bryanl is offline   Reply With Quote
Old 06-26-2011, 05:09 PM   #10
72duraburb
Hey guys this is the owner of the 72 burb with the duramax. Been trying to post on here but not real handy at the computer. I am from Carroll Iowa and this was my project over the winter. Tons of fun to drive it made the long haul on the power tour 4123miles door to door! Glad you all like it
72duraburb is offline   Reply With Quote
Old 06-26-2011, 06:46 PM   #11
Monty
duraburb, welcome to the board! freakin' awesome suburban. love the little touches like AC and hydroboost.
what transmission do you have in it?
Old 06-26-2011, 07:06 PM   #12
72duraburb
We put it on the chassy dyno in michigan 435hp and 889ft lbs of torq I think the 12 bolt has seen it match! Just put in a moser dana 60 with 35spline axles that should take care of the torq but now 4 a bigger turbo!!
Old 06-26-2011, 07:47 PM   #13
vectorit
What?
vectorit's Avatar
WELCOME 72duraburb!
You have to tell us all about your very cool burb!
Did you take pictures during your build? If you did, please post those up so we can all see how you did it!
There are few similar builds on this board, and it's cool to see another diesel powered burb here.
Again, welcome to the best place on the net for the Suburban!
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 06-26-2011, 08:45 PM   #14
72duraburb
Trying to get ready for good guys this weekend in Des Moines Iowa. I mat try the road course!?
Old 06-26-2011, 09:03 PM   #15
Flint70step
Flint70step's Avatar
Welcome to the board! Super cool Burb you got there.We are going to expect a build thread with lots of picture pleaseFirst off,please tell us how you found your Burb.I always love these stories.Thanks,be good
72 Cheyenne Super LWB 350/350 Factory A/C Tilt/Posi White/Med Red/White(on the way)
72 Custom Deluxe Burb(Arizona truck)Nice interior
Great patina
Project Patina Azul http://67-72chevytrucks.com/vboard/s...d.php?t=467668
Flint70step is offline   Reply With Quote
Old 06-27-2011, 02:24 AM   #16
67_C-30
67_C-30's Avatar
Awesome! I'm glad you found the board! I tried to find you at Montgomery, but I kept missing you. Very nice build. You have seen the crowd cheering when you made that first pass! Everybody was shocked!
My trucks
Old 06-27-2011, 08:41 AM   #17
72duraburb
The start of the build was a 72 burb that originated form arizona so it had front and rear air. Started with a bare frame and a 72 pickup cab to make sure of clearance problems along the way used a fatman front with air ride. moved the engine as low and rearward as I could get it then fabed some motor mounts and trans crossmember. The engine is a 06 lbz duramax with the 6spd allison trans with the 12bolt in question came a richmond gear 3.08 ratio yukon axles eaton center section and cover with bearing supports. I also used aftermarket tailing arms in the rear also did some tweeking on the engine at this point I was about a month or 2 into the project. started right before christmas. I have some pics of the build that I will try to get posted if I can figure out how. once all of the above was done I put the body of the burb on the chassy and started to enjoy! We left iowa with about 1200 miles on the swap to head to florida on the power tour and let the fun begin!! Since my return home i have replaced the front with the factory cradle and tubular arms 2in modular spindels an 13in wilwoods on the front and a dana 60 from moser and 12 wilwoods on the back. I am in the process of doing a stage 5 kit in the allison trans so I can make some more power safely. I will be at good guys this weekend car craft nats in minnisota and all deisel drags in bandimere in august. I thought the 13.1 was pretty respectful considering the 25 gal of fuel in the tank and our luggage in the back not to mention the first time in my life ever being on a drag strip. This project is the best build I have ever done it makes awesome power has air and can hold the wife and all four kids with room to spare!!
Old 06-27-2011, 08:48 AM   #18
Monty
tell me about the hydroboost mount plate. that looks like a clean install.
Old 06-27-2011, 11:21 AM   #19
72duraburb
www.hydrotechbraking.com cost is app 650 with no lines that the show prep non show prep is 550
Old 06-27-2011, 12:24 PM   #20
Hart_Rod
Hart_Rod's Avatar
Sweet build! If you can't figure out how to post more pictures, email them to me at robhartley@aol.com and I'll post them for you.
Hart_Rod is offline   Reply With Quote
Old 06-27-2011, 04:05 PM   #21
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very cool Burb! I'll keep an eye out for you this weekend. We'll be there and might run the auto cross too. My brother just came back from Brainerd with the vette this past weekend. It wasn't running very fast but atleast it made passes. See you this weekend. Ryan.
Ryan
1969 Chevy milk truck
Old 06-28-2011, 01:26 AM   #22
mosesburb
I had a V-8
mosesburb's Avatar
Cool Sub!!
So, uh, let me get this straight, you put a Duramax in a '72 Suburban, you started around Christmas and finished it sometime in May!!??? Good Gawd man!! That is beyond impressive!! Hell, it took me a year and a half to put a (comparably) "dumb" Cummins into mine (Dieselwrencher is still wrenching on his) and you crank this thing out in six months with a bunch of other mods. WOW!! Very nice.
You definitely need to post up many pics of your conversion. You mentioned you went back to the factory cradle. What was the reasoning behind that??
Way cool man!! I look forward to seeing some more of it.
13.1 with all of your luggage
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
Old 06-28-2011, 06:43 AM   #23
Number98
Prestige Worldwide
Number98's Avatar
That is one sweet burb you got there! Can't wait to see more pics...
Number98 is offline   Reply With Quote
Old 06-29-2011, 01:23 PM   #24
72duraburb
Hey guys! I started a new thread with pictures. Look for it on the build page: 72 with duramax (the build). Sorry some of the pictures are so small. They were taken on my cell.
Old 07-28-2011, 11:44 PM   #25
72duraburb
check it out on you tube at 72 duramax suburban burnout
