06-07-2011, 11:28 PM | #1 |
CPP Drop Spindles hitting upper control arms
Hi guys,
I installed my drop spindles from CPP and the steering is bound right tight, after looking at it, the upper control arm is hitting the top ball joint perch. Has this been seen before? How have people remedied this?. Thanks Lucas |
06-07-2011, 11:58 PM | #2 |
Laid Back
Re: CPP Drop Spindles hitting upper control arms
Are they cpp or western if western brand I have seen it before I just removed a little of the upper with a cut off wheel
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
06-08-2011, 12:28 AM | #3 |
Master Procrastinator
I have westerns from CPP and without the weight of the motor etc over them mine do the same, worst case you will have to do as mentioned before, it's not a major but if they're already painted it's frustrating
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506 20 Duramax tow pig 68 2wd short stepper project 77 2wd short fleet beater 52 short project |
06-08-2011, 09:15 AM | #4 |
06-08-2011, 09:43 AM | #5 |
awesome.... yep already painted and mounted, cotter pinned and greased why not just make a product that works ....
losing a little more faith in CPP every time I deal with them... |
06-08-2011, 01:31 PM | #6 |
Just make sure you have the correct upper ball joint in place as well. A ball joint with the wrong taper can allow the upper arm to sit closer to the spindle.
If it's just the matter of a fat casting on the spindle... grind away. Definitely not fun if you have already coated and finished the parts. Nate
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
06-08-2011, 01:49 PM | #7 |
~Rest In Peace~
i heard they made new upper shafts for the upper a arm
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
06-08-2011, 02:13 PM | #8 |
I'm 99% sure I have the right ball joint, it's a 70 and pretty sure these spindles were supposed to be good for the 70 ball joint.
Fastwillie what do you mean by new upper shafts? Is there supposed to be any differences in them from the originals? I put new MOOG ones in all arms already. |
06-08-2011, 02:16 PM | #9 |
Just when through the same thing, a few minutes with the grinder using a flap wheel took care of it.
06-09-2011, 01:23 AM | #10 |
http://67-72chevytrucks.com/vboard/a...1&d=1305085285 check out my pic I have the same problem and boughtbthe same CPP drop spindles. I tried diff ball joints and no help it hits when I air up the suspension. Grinder would suck parts are powder coated. I called CPP and got no help I even ended up buying there ball joints and no good. I just figured I wouldn't drive it at full lift anyway but still bothers me
Some progress is better then no progress |
