Old 06-08-2011, 10:08 PM   #26
SCOTI
SCOTI's Avatar
Re: reg cab shortbox dually
Originally Posted by GCncsuHD View Post
You can run the newer style 17s without the covers, and use whatever cap you wanted, you would need the McGard conversion double threaded lugs to adapt the newer thread on caps. As far as trim rings, not sure where to get 17" trim rings, possibly the lower trim level 2011+ 3500HDs may use trim rings? In 2011 even the base models get the 17" wheels because the brakes were upgraded and 16" no longer will fit over the brakes. Also maybe Ford or Dodge may have had trim rings on certain 17" dually wheels as they went to 17" wheels recently as well.
They make a 17" trim ring for the street rod crowd.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-09-2011, 09:06 AM   #27
LOW1TON
I have a 2000 gmc that I put 17" aluminum wheels on the outside and I wanted an 17" steel wheel for the inside so I contacted Trevor over at Tenneesee Wheel and Tire and he got me 2 new 2010 GM steel wheels the bolt pattern matched up and he machined out the center bore and made me hubcentric rings to fit my rear hubs. The whole thing worked out great but was not cheap but I think I am one of the few 88-98 body style duallys running 17s, here are some pictures.
"WIDER IS BETTER" (TRUCKS ONLY)
LOW1TON is offline   Reply With Quote
Old 06-09-2011, 09:34 AM   #28
SCOTI
SCOTI's Avatar
Those are 17's? The look like a larger diameter. I figured that machining the center bore out larger & using hub centric adapters would be the method I'd use if I went that route.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-09-2011, 09:35 AM   #29
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
I've said it before, but it looks amazing.
That's what my plan was with my Dodge wheels since they had the much larger center bores, but I still think it would be cheaper/easier to just add material by welding to the GM 17s then machine it back out round.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
