#76 |
Re: slamburban
Fred that is one sweet ride ,love that old school look.
I hope it's going to be a driver !!!
48 GMC Burb 51 Chevy AD 3100/C 4 byShannon 74 Chevy P 10 48 Double Duty 04 SS Burb 01 Springer HD |
#77 |
Re: slamburban
i finished the checker board on the firewall.i'm having a pin striper come next week to run black lines around the checkerboards.
#78 |
Re: slamburban
finished plumbing the fuel line. i got the procomp fuel pump,regulator,canister filter, and fuel pressure gauge off ebay for $100. its all aluminium line with 6an 37 degree flares and nuts from russel
#79 |
Re: slamburban
finished the brake lines. just have to do the power steering lines,positive cable, a couple air bag wires,prime the motor, adjust the valve,a few small things and the body goes back on the frame. then i need to figure out how to reduce the voltage to the coil for flamethrower distributor to fire the motor without a wire harness.
#80 |
Re: slamburban
Looking really nice!
Great find with the fuel system from ebay. Brian
current project; 1950 GMC "Junk Yard Dawg" http://67-72chevytrucks.com/vboard/s...d.php?t=635960 ___________________________________________ SOLD to "ONEBADFIVEFIVE" http://67-72chevytrucks.com/vboard/s...d.php?t=436406 |
#81 |
Re: slamburban
fredscarryall, great build. I love the checker board theme.
Shannon |
#82 |
Re: slamburban
i had spiderman come by and stripe the checkerboard. he only charged me $100 and he did a really good job.it really needed it,for some reason when you do checkerboard you cant avoid some overspray. unless tape off individual squares.
#83 |
Re: slamburban
before i fire the motor i am going to take the frame down to the exhaust shop and get the exhaust done next week.
#84 |
Certified Car Nut
Re: slamburban
Everything is looking really nice. Great job.
#85 |
![]() Join Date: Mar 2011
Re: slamburban
Really sweeeeeet. Nice job.
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#86 |
Local Redneck Authority
Re: slamburban
Glad I popped in the 47-59 pages, this is an awesome build! And you're fast too!
-Kevin four on the floor feel the beat in your soul movin to the rhythym pumpin til ya cant take no more dance if you want to do what you came to you cant ignore the feeling of that four on the floor |
#87 |
Tripple Five Fanatic
Re: slamburban
I've watching your build and you sir are doing a great job.
Tri5
1955 Chevy Stepside/LS1 drive train http://67-72chevytrucks.com/vboard/s...d.php?t=371513 |
#88 |
Re: slamburban
WOW. love it.
#89 |
Re: slamburban
ok waitin
Im stright up ESL student........ ![]() 94 s10 4x4 4.3/5speed (dd) 68 lwb GMC 350/4speed 52 5 window GMC I6/4speed 12v (8lugs and long bed) 53 bel air 235 I6/powerglide |
#90 |
Re: slamburban
its finally starting to resemble a complete truck. i had it towed to the exhaust shop.because the suburban suspension is so low the exhaust guy had to run some pretty tough tube angles. i had all the exhaust ran from underneath.then i can drop the exhaust once its back to the shop. so i clean up some of the welds and coat it with high temp exhaust silver paint.
#91 |
Re: slamburban
more exhaust pics.tomorrow i prime the motor and set the valves.on friday the body goes on the frame
#92 |
Re: slamburban
fredscarryall, looks great and I love the finished checker board. Cant wait to see it with the body on.
Shannon |
#93 |
Re: slamburban
Everything looks great, can't wait to see the body on frame. Exhaust turned out nice.......Jim
#94 |
Re: slamburban
This is surely amazing!
Great idea to take down the chassis without the body for the exhaust work to be done. Keep the pics coming!!! Brian
#95 |
Re: slamburban
i primed the motor and started it today for about 20 seconds.it ran really smooth for the short time it ran.i couldnt get the fuel regulator to adjust under 15 pounds. i needed to run 7 lbs. then i lost fuel pressure. i think the regulator is messed up. i got the body on the frame. it looks good. i forgot my camera so i will post some pics tomorrow.i was going to paint my inner fenders and radiator support. i think im going to powercoat them blue like the frame.
#96 |
Re: slamburban
i think i've found my new love!!!
great work man i see charlie from charlies chop shop is he still in portland Or? if thats the same guy i can remember meeting him several times at the portland swap meet lol patrick peets
"mary lou" 1938 GMC T155 project (on hold) "mearle" 1966 dodge D100 4x4 (sold) "candace" 1969 chevy C50 (free truck!!!) "kelsey" 1976 chevy silverado 30 CS (traded) "maxwell" 1979 cheyanne 1 ton long box 4x4 (sold) "polar bear" 2013 dodge durango R/T (mamma's rig) |
#97 |
VA72C10
![]() Join Date: Mar 2008
Re: slamburban
very cool project. Love the checkerboard theme and the matching painted frame will be nice!
Quick ??? on the brakes...noticed how low the prop valve is...do you need residual valves? I was going to have to run them on my truck with a frame mounted master/prop valve so not sure if you're okay with the master on the firewall and the prop valve on the frame or not...
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#98 |
Re: slamburban
phantom309 its the same charlie. he has moved to 5140 se circle ave portland, oregon now
#99 |
Re: slamburban
va72c10 i dont think i need a residual valve. unless your master cylinder is below the bleeder valves. like in a frame mounted master cylinder set up.the residual valve prevents fluid from backflowing to the master cylinder causing a spongy pedal.the master cylinder being lower thenthe bleeder does something with the pressure and gravity. i bought a disc/disc combination valve that does metering (which holds off pressure until rears catch up)and proportion (which gives the rear full pressure to a certian point so the back doesnt lock up)
#100 |
Re: slamburban
heres some pics with the body on the frame. now comes the fun part. putting everything together. it goes together alot easier the second time around. after you mock everything up, remove it ,paint it and put it back on. everything actually fits.didnt get much done today. i did the rubber hood gaskets that screws on the cowl panel. to prevent the hood from scratching the newly painted cowl. then i look the power steering lines down to the hydraulic shop to get the lines made. next week i should get alot done.
