07-28-2003, 12:48 PM | #1 |
It followed me home?
weight reduction
I was talking to a guy at the track this weekend and he mentioned taking out some crossmembers and things form his truck (72 lwb) and he shed about 500lbs. Any ideas on this? anyone messed around with weight reductioon on their truck?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
07-28-2003, 01:01 PM | #2 |
yeller
Crossmember? As in bed-crossmembers? I would not remove them since they add weight over the rear wheels and in a PU you need all the weight back there you can get.
Try this.. -glass hood -glass bumper -glass fenders -glass inner fenders -remove inner fenders -alum wheels -bench seat as opposed to buckets -one racing seat as opposed to bench/buckets -remove heater/AC/radio stuff -alum heads/accessories -plastic HL bezels as opposed to metal ones -lexan windows -no carpet/sound deadening/headliner -lose some bady fat (not saying you have some, but if you do...) -run 1/2 tank of gas as opposed to full (unles you have a relocated tank) -wear shorts, not pants -wear short sleeve shirt, not long -shave your head -clip finger/toenails -wax vehicle to make is less wind resistance -put TG down -move battery to the bed -elec fan as opposed to clutch -if you had 4 wheel drum brakes you could adjust them to zero drag -if you have power windows/locks...conver to manual operation -remove door panels/dash pad just some ideas to get you thinking. ...Jeff Last edited by bigblock73; 07-28-2003 at 01:09 PM. |
07-28-2003, 01:05 PM | #3 |
www.73-87chevytrucks.com
move the battery to the bed
move the gas tank to the back manual accessories instead of power remove all cushy accessories ( AC/ PS pump)
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
07-28-2003, 03:19 PM | #4 |
Live from Atlanta
You can always take about 5 lbs of air out of each tire....That shoud be good for 20 pounds.
Paul |
