Old 06-09-2011, 06:00 PM   #1
todd99
C20 Rear Wheel Bearings
I am getting ready to take a long trip in my truck and have a question about the wheel bearings.
In a 3/4 ton 8 lug 4:10 rearend do the bearings need to be packed or are they lubricated by the differential fluid?
1971 C20 Longhorn Custom Camper
todd99 is offline   Reply With Quote
Old 06-09-2011, 06:05 PM   #2
john
member #16
john's Avatar
Re: C20 Rear Wheel Bearings
Yes they are lubricated by the diff fluid.
john is offline   Reply With Quote
Old 06-09-2011, 06:08 PM   #3
todd99
Awesome! Thanks.
Old 06-10-2011, 08:14 AM   #4
eagleuh1
eagleuh1's Avatar
Where you going? My 3/4 with Dana 60 made it to Tonopah, Az. from Arkansas fine towing a travel trailer from Arkansas. All I did to it was replace pinion seal and new Synthetic lube. Make sure it doesn't have any leaks and new topped off lube. Good luck with yours. Jim.
eagleuh1 is offline   Reply With Quote
Old 06-10-2011, 10:22 AM   #5
todd99
I am going from Prescott, AZ to Chico, Ca. I will be towing a trailer. The rearend leaks where the driveshaft is connected, but I am going to top it off before I leave. I run royal purple synthetic lube.
