Closed Thread
Old 06-10-2011, 10:14 PM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
Mechanical gauges on a LS swap
Here is my swap:
85 SWB, 2004 6.0l w/Vic Jr 4150 style TB and some other goodies backed by a th400
My questions are:
Can you use mechanical gauges for the oil press, and water temp? If so, where can I get the appropriate adapters that go into the block/head?
I will be swapping out my dash for a 64-66 truck dash and I don't want to buy good gauges until then. I already have the mechanical water and oil pres and would like to just hook them up. I will still be able to use my speedo with the pass thru VSS from Dakota Digital and i am buying my tach bc I am going to mount it on my dash.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline
Old 06-10-2011, 11:01 PM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Mechanical gauges on a LS swap
Yes. water temp can be pulled off one of the heads, just pull the plug and tap the hole for your sender or you can get adapters thru Autometer as well as Speedway Motors. As far as oil pressure, not sure on the LQ4 but there may be a place to tap for oil pressure on the back of the valley pan. If not, many tap the small cover (for motors w/o oil cooler?) near the oil filter.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline
Old 06-11-2011, 02:03 AM   #3
C10CORIE
C10CORIE's Avatar
Anybody have any pics of this??
C10CORIE is offline
Old 06-11-2011, 11:13 AM   #4
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
You can replace your oil press sender with this and run a mechanical gauge off of it.
http://www.summitracing.com/parts/ATM-2268/
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline
Old 06-11-2011, 11:56 AM   #5
softballnrd27
Thanks guys, 1 less thing I have to worry about now.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 06-11-2011, 06:00 PM   #6
68GMCCustom
see the plug w/allen wrench fitting? Its a plug for the cooling system and where your temp sensor can go. Usually the drivers side (at the front or block) is used, I removed the passenger side (at the back of block) plug and tapped it for 1/8" NPT or maybe 1/4" NPT...can't remember. then put the plug in the drivers side hole left after removing oem sensor.
Kurt -
Old 06-11-2011, 06:00 PM   #7
LEEVON
Moderator
LEEVON's Avatar
Easy as pie, sorry to break it to ya'll but you don't have to drill and tap anything. Click on the links below, they even have a picture of where they go.
Exhibit A: in place of a hex plug in the head:
http://www.speedwaymotors.com/LS1-Wa...pter,8195.html
Exhibit B: in place of the stock oil pressure sending unit:
http://www.speedwaymotors.com/LS-Ser...ter,20928.html
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline
Old 06-12-2011, 12:10 AM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I used the blockoff for the oil cooler off of my LH8 pan
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline
Old 06-12-2011, 10:31 PM   #9
68GMCCustom
Leevon I bought both of those. I used the one for oil pressure (tapped off top/rear of valley pan) sensor which is hidden for the most part...but much prefer the look of the sensor screwed directly into the head for the thermostat, rather then into something that you then screw into the head making for a longer assembly.
My sensor wouldn't work with the Speedway adapter anyway.
Kurt -
Old 06-14-2011, 11:04 AM   #10
Shon
I have the water temp mechanical sending unit in my heater hose, cheaper than the adaptor in the head but you need one of them hooked up for the PCM to work but can find a different source for the mechanical.
Oil pressure sending unit is not needed for the PCM so I got the adaptor from Autometer and put the mechanical unit in there; back of the black behind intake.
For the tach, set it up for 4cyl mode and if that is not an option then the PCM can be changed to work if you wire it from the PCM.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline
Closed Thread
