Old 06-03-2011, 12:51 AM   #51
KrazyRay
KrazyRay's Avatar
Re: Parting 72/67/81 SWB 4X4
Originally Posted by CHEVY_BOI93 View Post
okay. can you sell them to me for cheaper Ray? I don't want to sound like a low baller but i got my driver side inner fender at the junk yard in better than FAIR condition. for about ($9). Just let me know what you can do Ray?
By the way any rust on the inner fender?
I only have a couple good passenger sides because 90% are rusted out under the battery tray. I have a bunch of driver side inner fenders because they usually don't rust out. With shipping being added, you will probably be better off finding one local.
Thanks,
Ray
KrazyRay is offline   Reply With Quote
Old 06-03-2011, 12:52 AM   #52
KrazyRay
KrazyRay's Avatar
Originally Posted by 1972hays View Post
hey doughs it have front disk brakes
Yes, I have several 44 front axles to choose from.
Thanks,
Ray
Old 06-03-2011, 12:55 AM   #53
1972hays
1972hays's Avatar
cool then it has the dust shield driver side
1972hays is offline   Reply With Quote
Old 06-03-2011, 12:58 AM   #54
CHEVY_BOI93
1972 hays....was the question about the disk brakes for me or for ray?
CHEVY_BOI93 is offline   Reply With Quote
Old 06-03-2011, 12:58 AM   #55
KrazyRay
KrazyRay's Avatar
I will check to see if I have a loose dust shield. I like to sell axles complete because once I tear it down, its hard to sell the rest of it.
Thanks,
Ray
Old 06-03-2011, 08:40 AM   #56
kellytheaker
Ray i require the border of the complete hole and it does not need to be a complete -1 piece - all i am doing is the 2 wheel hole that was hacked is now the same size as a 4 wheel hole and i am going to remove the nut and metal strip that reinforces the tunnel . i need the 2" circumferance around the tunnel in portions - the sides have strips of metal under the tunnel that have the nuts attatched to them and the top has just the nut spotwelded or heated to the tunnel . i need the total outer portion but it can be chopped to fit in a small box just dont cut the metal strips up that are used on the sides and i will remove the spot welds and atatch to my tunnel
kellytheaker is offline   Reply With Quote
Old 06-03-2011, 09:58 AM   #57
KrazyRay
KrazyRay's Avatar
Kelly, I can do $25 plus shipping. If it fits in a small flat rate box, it will be around $15 to ship.
Thanks,
Ray
Old 06-03-2011, 10:32 AM   #58
kellytheaker
sounds good and you are aware of what i need the perimeter where the bolts are and the sides have a strip it looks like that the bolts are part of - a flat piece of metal that the bolts are atatched to . and chop it up just ensure that the strips are not cut into 2 and i will detatch when i get the pieces of the perimeter pieces . anything with a nut i need and i will tack in once removed . thanks
Old 06-03-2011, 04:44 PM   #59
Evan68chevy
It sounds like your selling the connecting points for the transmission tunnel but are you selling the high hump? or do you have one? I was also looking for a clutch pedal/ pedal assembly for my auto-manual switch im doing right now. And if you do have either of these do you have a price? I live in roseville so could come pick anything up
Thank you
Evan
Evan68chevy is offline   Reply With Quote
Old 06-03-2011, 05:19 PM   #60
KrazyRay
KrazyRay's Avatar
Evan, I have a clutch/brake pedal assembly for $20 and a high hump for $30. pm sent
Thanks,
Ray
Old 06-06-2011, 02:16 PM   #61
1972hays
1972hays's Avatar
it was for ray but if you have one and he cant find one or something cool thanks for looking a lot
Old 06-06-2011, 03:41 PM   #62
KrazyRay
KrazyRay's Avatar
Sorry, I don't have any loose ones. If I come across one, I will let you know.
Thanks,
Ray
Old 06-12-2011, 01:37 AM   #63
KrazyRay
KrazyRay's Avatar
Exhaust pipes and rams horn manifolds sold to Fesser. Frank, Thanks for coming over...its nice to see you again. I want to let everyone know that Frank is a stand up guy...A great guy to do business with. He even delivered some tires for me that were an hour away.
Thanks,
Ray
