Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 06-12-2011, 12:46 PM   #1
Pyro
Pyro's Avatar
New vendor for you wiring needs!
Well, sort of new. I've been around awhile but have been so busy setting the new shop up that I didn't get much time to be on here. Now that I have working internet at the shop it's a lot easier
Downriver Motorsports Wiring is a michigan based company. We handle everyhting from basic repair to full vehicle wiring. If you need a custom wiring harness built from scratch to fit a LS engine in you truck we do that. If you have a factory harness that you want modified to work in your truck we do that too.
I started the company after building prototype harnesses for 10 years for a supplier for the Big 3. While I was doing that I started wiring drag cars, hot rods, and such on the side. We only use top quality parts and never skimp on quality. If you have us modify a stock harness for you it won't come back without new coverings on it, profesionally taped using correct tape, not just cheap vinyl tape, and any unused circuits will not just be taped inside the harness, we remove the circuits properly. If we have to remove a wire from a splice we redo the splice so that one wire isn't hanging out. When the harness is done it will be bundled with the smallest diameter covering that will fit.
I know not everyone can bring thier truck to us to have it wired, but if you can give dimensions of what you need built for harnesses we can build it.
I also have a 1986 GMC Sierra standard cab long bed that's getting a 6.0 and a 4L80E setup and a 1991 Chevy Suburban that's rusty as heck, but still hauls like the day it came out of Flint, keep your eyes on the forums for updates on these two.
Pyro is offline
Old 06-13-2011, 01:24 AM   #2
SBTork
Garage wrench
SBTork's Avatar
Re: New vendor for you wiring needs!
very cool, welcome
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline
Old 06-13-2011, 04:13 PM   #3
Clyde65
Clyde65's Avatar
PM sent
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline
Old 06-13-2011, 05:55 PM   #4
68 short step
could i geta idea on price for a harness for a 5.3/ 4l60e. that the wires are routed towards the rear of the engine...wiht the fuses and relays..
68 short step is offline
Old 06-19-2011, 12:47 AM   #5
Pyro
Pyro's Avatar
PM sent!
Pyro is offline
Old 06-19-2011, 10:03 AM   #6
Warrens69GMC
Warrens69GMC's Avatar
Whats up with the website?
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Warrens69GMC is offline
Old 07-21-2011, 09:49 PM   #7
late68
late68's Avatar
PM sent.
1968 C10 SWB Dropped 5 in tha back 3 in tha front
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=470902
late68 is offline
Old 07-21-2011, 10:58 PM   #8
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Welcome to the board as a vendor! Do you ever get into the diesel swap harnesses?
Ryan
1969 Chevy milk truck
Dieselwrencher is offline
Old 08-09-2011, 02:48 PM   #9
smoky02
Location: Sunny, Florida, some might call it South Alabama
Could I get this also?
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline
Old 08-09-2011, 02:59 PM   #10
Clyde65
Clyde65's Avatar
website still not working
Clyde65
Rebuild of Clyde
support our troops!
Clyde65 is offline
Closed Thread
