Old 06-13-2011, 11:05 AM   #1
JJAB
4l80e/4l60e
Guys, I was just wondering. I currently have a 6.0 with a 4L80E. The transmission seems to have a converter whine. It has the correct amount of transmission fluid. Anyways, I have access to a 2500 stall converter for a 4L60E. Can I use it in my 4L80E? Just wondering!!
JJAB is offline   Reply With Quote
Old 06-13-2011, 12:55 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 4l80e/4l60e
The 80E uses 6 bolts to the flywheel, I believe the 60e does not.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-13-2011, 01:41 PM   #3
Clyde65
Clyde65's Avatar
Re: 4l80e/4l60e
What he said^^^^^^
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-13-2011, 05:06 PM   #4
JJAB
Re: 4l80e/4l60e
Not trying to be a smart _ _ _, but I am aware of that. Are the both of you saying that it wont bolt to the flexplate.
Old 06-13-2011, 05:14 PM   #5
clinebarger
Re: 4l80e/4l60e
4L60E & 4L80E converters do not interchange. I would like to know more about this whine, Does it only happen in 1st gear? All the time?
clinebarger is offline   Reply With Quote
Old 06-14-2011, 12:31 AM   #6
5150.4.67
Re: 4l80e/4l60e
^^^Agreed. Get that whine figured out before you are replacing more than a converter..............
5150.4.67 is offline   Reply With Quote
Old 06-14-2011, 10:41 AM   #7
JJAB
Re: 4l80e/4l60e
The whine is consistent throughout each change of the gears. The whine was rather loud at one point when I first did the the new engine start up. Now that I am driving the vehicle and of course checking vehicle fluids daily, the whine is not as loud but is present It actually sounds like a real quiet gear drive, but it is definitely coming from the converter. My truck is somewhat sluggish aslo.
Old 06-14-2011, 11:55 AM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 4l80e/4l60e
any problems with lock up?
Old 06-14-2011, 05:37 PM   #9
JJAB
Re: 4l80e/4l60e
I do feel the tranny lock up. But, it slips in and out of lock up. Currently, the truck is being driven in town, so a lot of stopping and starting. It just really drives like I have a stall converter and it is just the original converter that came with the 4L80E.
Old 06-14-2011, 09:17 PM   #10
clinebarger
Re: 4l80e/4l60e
The fluid pump can make whining noises (wore out pump) or its injesting air from a bad pump to filter seal, cracked filter housing, low fluid level or restricted cooler flow.
The converter could be bad, BUT a bad converter can & will damage the transmission.
Take it to a transmission shop & have them do a line pressure test in reverse should be at least over 250psi, If not its rebuild time.....How many miles are on your trans? 4L80Es do fail. They are VERY stout transmissions, but they dont last forever.
Old 06-15-2011, 01:32 AM   #11
5150.4.67
Re: 4l80e/4l60e
I, for one, am glad guys like clinebarger take the time to answer posts to help folks out. I'll say it in case someone forgets...THANKS!
Old 06-15-2011, 09:50 AM   #12
JJAB
Re: 4l80e/4l60e
Clinebarger, I am very appreciable to your answer about the tranny. I do plan on having the tranny tested as you said. I will keep you posted on the outcome.
Old 06-15-2011, 10:22 AM   #13
Clyde65
Clyde65's Avatar
Re: 4l80e/4l60e
Chris, you rock!
i'll send a check Monday..JK
Clyde65
Rebuild of Clyde
support our troops!
Old 06-15-2011, 09:46 PM   #14
clinebarger
Re: 4l80e/4l60e
Thank you.
Let us know
Originally Posted by Clyde65 View Post
Chris, you rock!
I dont take Rubber Checks!
Old 06-15-2011, 11:13 PM   #15
Clyde65
Clyde65's Avatar
Re: 4l80e/4l60e
awwwww Man, that hurt dude, hurt real deep too......
Clyde65
Rebuild of Clyde
support our troops!
