![]() Join Date: May 2010
Removal of outer rear window steel
Guys, I am getting ready to replace my rear window with a solid piece, and my super has the stainless trim that goes around the lower side of the window.
Is there an easy way to remove this piece? Also when I install the new rubber seal do I need to put anything on the outside of it? Adhesive or anything? |
![]() Join Date: Apr 2008
Re: Removal of outer rear window steel
Cut the seal with a razor from the inside and once it is out it should be easy to remove.
