Old 09-15-2006, 04:05 PM   #1
John Fabris
TOTY 2006
John Fabris's Avatar
Picture request, C20s with 2500HD Rims!
Hi All,
Have a buddy that wants to puts some chrome wheels on his truck, a 67 C20 worktruck, and I told him about using the chevy 2500HD rims like I have seen on Wes's truck and Chickenwing's truck. Was hoping to find some pictures of our trucks with these rims to show my buddy. Thanks!!!!
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 09-15-2006, 11:27 PM   #2
Aarons72s
Re: Picture request, C20s with 2500HD Rims!
I agree I would like to see that too! Here is a bump.
Aarons72s is offline   Reply With Quote
Old 09-15-2006, 11:53 PM   #3
mcw1
Here's a pic of my '69 with late model 8 lug wheels and GMC center caps. I haven't figured out how to get the rear caps mounted yet, as they don't fit over my hubs. I even tried going to a dually center cap, but to get them to fit I have to put a 1/4" washer on the lug before I put on the lug nut.
'72 K5 Blazer, waiting to start engine!
'69 GMC 3/4 Custom Camper
'69 C10 Stepside
mcw1 is offline   Reply With Quote
Old 09-16-2006, 01:02 AM   #4
cheyenne10
cheyenne10's Avatar
Here are a couple I have.
Bob
cheyenne10 is offline   Reply With Quote
Old 09-16-2006, 12:23 PM   #5
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Those do look good and they are cheap! I don't see the big problem with the new offset, that some people are complaining about. They seem to set in the wheel wells just about right.
Anyone have any inside clearance problems? I have run the new steel ralley wheels for years without trouble.
PICKMUP is offline   Reply With Quote
Old 09-16-2006, 03:15 PM   #6
72freak
Rottenwood Garage Member
72freak's Avatar
hummer wheels
72freak is offline   Reply With Quote
Old 09-16-2006, 03:32 PM   #7
cheyenne10
cheyenne10's Avatar
I remember that picture of your burb with hummer wheels. I wonder if they would work on 3/4 ton 4x4 too? Hmmmmmmmm. Might need 2 sets of tires/wheels!!
Bob
Old 09-17-2006, 03:20 AM   #8
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
I can't seem to find a picture but IIRC Board Member "Brewski" had them on his '72 GMC 3/4 Ton 4x4 for a while.
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
Old 09-17-2006, 07:16 AM   #9
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I remember that also, but can't find the pic's either
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 09-18-2006, 11:38 PM   #10
John Fabris
TOTY 2006
OK, next question, What did you do for the lugnuts size difference? We found a set and they are going on a 67 3/4 longbed, and noticed that the lugnuts that came with the rims are bigger then the factory 67 studs. Did you find new lugnuts or replace the studs with bigger studs...
John Fabris
67 C10 SWB
Old 09-18-2006, 11:53 PM   #11
cheyenne10
cheyenne10's Avatar
I bought a set of 32 nuts off of ebay. There is a dealer on there. Right around $42 shipped if I remember. Reputable local tire store (Les Schwab) just stared at me with blank stare and said not available. The fake plastic covers screw onto regular nuts for look. The inside thread is standard threads to fit our studs and outsides are metric to fit caps.
I beleive these are the ones I got.
http://cgi.ebay.com/ebaymotors/Wheel...spagenameZWDVW
Bob
Old 09-19-2006, 12:18 AM   #12
John Fabris
TOTY 2006
Hey Cheyenne10, do you have that ebay sellers name?
John Fabris
67 C10 SWB
Old 06-15-2011, 09:36 AM   #13
mikewarme
Do you remember if that truck had the large hub from the floating rear axle? I want to use those wheels on my 69 but fear the caps won't fit with my axle.
mikewarme is offline   Reply With Quote
Old 06-27-2014, 09:56 AM   #14
AZ1970k20
Hey Guys,
I am just in the process of putting the 2500 rims on my 70 K20. On my truck,I need 1/2 20 thread (not sure if that is stock), and the lugs that came with the rims where metric.
I found the following lugs at Napa that work for the caps. Just wanted to share my find.
Part Number: NOE 6414237
http://www.napaonline.com/Catalog/Ca...237_0437516167
AZ1970k20 is offline   Reply With Quote
Old 06-27-2014, 10:47 AM   #15
FirstOwner69
FirstOwner69's Avatar
Originally Posted by AZ1970k20 View Post
Hey Guys,
1/2"-20 is stock for the 1970 3/4 ton. Here is an eBay listing for what you need. http://www.ebay.com/itm/32-LUG-NUTS-...item46216ed5a1 I see you are in the Phoenix area. I bought a set of these at the monthly(?) swap meet at Glendale Community College. I believe it was from this eBay seller. At least his sign said Lug Nut King.
FirstOwner69 is offline   Reply With Quote
Old 06-27-2014, 12:11 PM   #16
airdale94
airdale94's Avatar
It must be the Dana axles that the center caps won't fit, because mine fit on both the H052 and the 14bolt I swapped.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 06-27-2014, 09:12 PM   #17
FirstOwner69
True. I put Hummer H2 wheels on mine with an Eaton without a problem with the caps. Davepl used the same wheels and caps on his 70 with a Dana and had to use spacers in the rear to get the caps to fit.
Old 06-29-2014, 10:47 PM   #18
AZ1970k20
Thanks everyonel
Old 06-30-2014, 08:44 AM   #19
OhioDan
OhioDan's Avatar
Had to use 1 1/4" spacers between drums and rims on my Dana 60 to get centers to work. I also purchased 1/2X20 lug nuts from "Lug Nut King" to mount new rallies on my 70 GMC.
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 06-30-2014, 12:51 PM   #20
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
The "Garden Truck" has 2005 Wheels and tires. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 06-30-2014, 01:02 PM   #21
zellway
zellway's Avatar
When I was looking around I found a set of Dodge ones that worked out nice. I will be installing bowties over the rams caps. Just a diffrent option. I even got to run all the lugs.
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline   Reply With Quote
