Old 06-13-2011, 09:13 PM   #1
willstruck
more power out of Edelbrock 1406
So, I have an Edelbrock 1406, which is built for fuel economy. Came on the truck. I want more power out of it. Can I get more power out of changing jets and rods, what else? I'm new to carbs. What size jets would you recommend? It's a daily driver/offroad truck.
'85 k10 long bed, 6" lift. 35" tires. 350, Edelbrock intake/carb, headers, dual exhaust. Automatic.
willstruck is offline   Reply With Quote
Old 06-16-2011, 03:40 PM   #2
Goldfinger
Goldfinger's Avatar
Re: more power out of Edelbrock 1406
replace the rods and jets tune it slightly rich. it will give you a good bit of power.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 06-16-2011, 04:56 PM   #3
hugger6933
Is this truck the one in your description line? With 35 inch tires? You may need more gear to get that thing moving. The carb will help but getting more power out of it is gonna be in the tune. Just adding bigger jets may not be what is best for your combo. What size engine do you have? what camshaft is in it? What type of exhuast does it have? There are as many varibles in that as there are people to tell you what to do. First thing to do is make sure you are runnig with a good tune up. Check the plugs wires and the such. When was the last time it had a cap and rotor and a set of new plugs and wires? Get it tuned the n go to the carb for more. The Edelbrock website has a owners manual that can be a great asset to you with that carb.
hugger6933 is offline   Reply With Quote
Old 06-16-2011, 05:09 PM   #4
nate_g_2003
nate_g_2003's Avatar
I have the same carb (1406 w/ electric choke), and the manual for it is very informative on tuning it. Tells you everything you'll need to retune it. The regear is actually a better idea than trying to retune a 1406.
-Nathan-
1972 GMC K2500 Suburban "The Project"
2013 GMC Sierra 1500 SLT Z71 "The Daily Driver"
2005 Ford F150 Lariat SCrew 2WD "The Daily Driver" SOLD
1995 GMC Sierra C1500 SLE "The Daily Driver"SOLD
2003 Ford Ranger Edge 2DSC 2WD Flareside "The Daily Driver/Project"SOLD
nate_g_2003 is offline   Reply With Quote
