Let see some wheel tubs
I want to do rear wheel tubs on my 57 chevy.what are you guys using?
#2 | |
~Rest In Peace~
Re: Let see some wheel tubs
some guys take old tubs and weld two of them together
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
On my 57 I just needed about 1" more of clearance and I did not want to do the massive pro stree tubs. I found a late 40's Dodge truck in the wrecking yard and it had nice little 2" wide factory tubs. So I cut these and used them. They worked out nice.
Another option is to go to a trailer parts supply and buy a set of trailer fenders and use those as tubs. http://www.etrailer.com/Trailer-Fend...F13X36-1R.html |
I have a set of Dennis Carpenters universal wheel tubs for my '49. The tubs are around 2.5" wide and come in different diameters for different size wheels/tires. I will try to post some pics of them asap.
I'm going with the trailer fender set up. Norther Tool and Tractor Supply has the trailer fenders in stock. Plenty of sizes to choose from.
My build project http://67-72chevytrucks.com/vboard/s...=1#post4158671 |
Yellow truck club
This is what I did on my 59.
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() ![]() ![]() ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
#7 | |
x3 on the trailer fenders, there wide enough to cut in half and do both sides with one a grand total of $20
Old Heap Driver
Since mine has a bridge notch and raised floor, I went with this...............
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
#10 | |
Yellow truck club
You could also use a set from a 58-58 straight side as well.
I'm running 31x18.50's. It's a different look, but you can't beat shiney!
